Starting resaw
Wiley Horne--So. Calif.
Hi All,
New writing desk project involves veneering both sides of a Baltic birch ply top. 3/32" to 1/8" veneers top and bottom. My friend Konrad Sauer already resawed the show side satinwood on his bandsaw. Could not believe the yield he got out of that single board.
I need balancing veneer for the bottom side of the top. I have some sugar maple, so will use that for the balancing veneer and interior framing of the drawer box. I have a small bandsaw, but it won't handle the 9" wide maple board I need the veneers from. So I need to hand resaw two 1/8" maple veneers, 9" x 38". Have begun that job, and it's not a real tough job, just takes a while.
Here's the work getting started:
http://www.flickr.com/photos/78661951@N07/8220626129/in/set-72157632104394661/
Closer shot of saw and kerf:
http://www.flickr.com/photos/78661951@N07/8221704260/in/set-72157632104394661/
Saw is a Mitsukawa rip, 425mm (17"), 3-1/2ppi, with rake angle 0 to just a hair negative (aggressive; tilted in direction of cut). I started the kerf with a smaller saw, then switched to this saw after I had about an inch of kerf on both faces.
At first, I was a little disappointed when I received this saw in the mail, thinking the toothing was too coarse for dry hardwood. But it seems just right in use. I had left the toothing up to Mitsukawa--just told him I wanted to resaw hardwood. I made the order through Tomohito Iida, and he did a fine job as go-between. I've had nothing but good experience with Tomohito. Here he is:
http://japantool-iida.com/faq/2008/05/how-to-order-2.html
I can't get to my regular bench to do this work, because of the way life around the house is arranged (don't want to wake my wife). So made up a small bench I could stash on the porch. It's less than 4' long, but it's what this desk is gonna get made on. It's sturdy: LV's cast iron leg set, with 2-1/4" butcher block top from McMaster Carr (Rob Lee suggested them for this item!); wrapped the top on two sides with a 2" x 7" apron; hung an LV twin screw vise on one end.
Will post updates from time to time.
Wiley
