New WoodChat!
For mounting measured drawings...
Robert Tutsky
Robert Tutsky
don't use the spray adheisive that is commonly used. The stuff is terribly toxic and sticks to everything, you can also feel it adhering to your skin as it floats in the air. Use this instead:
Non toxic, cheap and easy to apply to paper. To remove the drawing or reactivate the adhesive just moisten the paper with a wet paper towel. The residue left behind on the wood is easily washed off with water.
Re: For mounting measured drawings...
scrollsaw patterns
Charles Yawn
Looks like a good idea. I'm gonna try this in mounting my scroll saw patterns to wood blanks. Thanks for the heads-up.
Charles
Re: scrollsaw patterns..Let us know
Ron in Sterling, CT
Charles,
Let us know how it works out. I would be interested in it for scrollsaw patterns also.
Ron
Charles Yawn
Ron, I bought some of this glue today. Used it to apply a test sheet of copy paper to a smooth side of plywood. It worked well - good adhesion - easy to remove and reapply. I plan to leave it on the test plywood for several days to see if anything changes and to see how it cleans off the wood (supposed to come off with soap and water). Maybe make some cuts with the scrollsaw to see if that is any different. It's fairly cheap; about a dollar a tube. It is somewhat messier to apply than spray and it is harder to get a smooth, even surface like spraying, but like Robert Tutsky said, you don't have to be concerned with overspray and fumes. Finally, it was cool that it goes on purple and dries clear. I enjoyed that, but I am easily entertained! :)
Charles
Thanks for the info ...
Ron in Sterling, CT
Charles,
I will have to get some and try it.
Ron
Robert Tutsky
A few tips...
Robert Tutsky
It doesn't have to be Elmer's. I found a four pack of a generic adhesive on ebay at a good price with free shipping and it works just as well.
If you have a large pattern don't worry about the glue drying before you apply it to your wood surface, just spread the glue evenly over the areas of your pattern where you want the the pattern to adhere to the wood. If the glue seems dry, no problem, just place the pattern down and lightly sponge the backside of the paper surface with water. That will reactivate the adhesive. Give it a few minutes to dry and you're all set.
The best way I found to remove the pattern paper is to sponge it with water again and lightly scrape the pattern paper off the wood.
The remaining glue on the wood is easily sponged off with a damp sponge.
Hey, it's much better than spraying that foul adhesive.
