New WoodChat!
Sanding Block
Sanding Block
Robert Tutsky
Sanding Block
Robert Tutsky
Here I go again, making stuff to make stuff. This time it's sanding blocks. Normally their use is towards the end of a project but I figured that if I had these available now I wouldn't be in a rush cobbling something together just to finish a project. They are designed to use a section of a 9 x 12 size of a sheet of sandpaper, four pieces cut approximately 3" wide x 9" long with a little strip left over.
The block is basically a sandwich of 1/2" baltic birch blocks. Walnut knobs hold it together keeping the sandpaper taught. Inkjet printed labels indicate the grit of the sandpaper installed in the block. The knobs have birch inlays covering the 1/4" holes for the threaded rods, smaller knob inlay is recessed slightly for the index finger rest.
Blocks are clamped and drilled a 1/4" hole through the center. A roughed up rod is epoxied in the upper block.
Threaded rods are epoxied in place. Octagonal mortises are chiseled to accept the 1/4" nuts and epoxied into place.
Finally a shot of three made showing different grits installed.
I am hoping that using these sanding blocks will help to make sanding more pleasurable.
Re: Sanding Block
My.  And Wow.  Neat design
A step up from the black plastic blocks from the Ace Hardware store that I use.
Re: Sanding Block
Clever
Re: Sanding Block
Robert Tutsky
Well, there are plans...
Robert Tutsky
on the drawing board for an accessory that mounts to the block with a hose that runs to a facial mask that removes surface dust. It is powered by simply inhaling and exhaling while sanding. Probably available early spring.
Re: Sanding Block
Robert Tutsky
Detailed Plans Available...
Robert Tutsky
Just let me know by giving me an email notification if you would like a detailed pdf plan. rtutsky @ gmail . com.
Re: Sanding Block
Re: Hard surface?
Bruce McCrory
I have always wondered about hard base under the paper vs. a slightly padded base, like felt or sponge. I seem to get better "bite" and longer lasting abrasive using a pad. It also seems to avoid burnish on the wood and glazing on the paper.
