New WoodChat!
widening dados
widening dados
widening dados
Jerry Gibbs
What is the best way to slightly widen a dado? I am fitting some plywood into dados that are tight. I have been using sandpaper fitted over a smaller piece of wood. The dados are about 7/16 and are in poplar and plywood. Is there a more elegant and efficient way? Jerry
Re: widening dados
Side rabbets?
John in NM
There are a variety of planes made for this, from LN, Lee Valley, Kunz, and Woodriver.
Re: widening dados
I have the Stanley 79, but
Bruce, a MN Galoot
I suspect the LV version is a lot better. The Stanley works ok.
Re: widening dados
Re: widening dados
Bill Tindall
All these plane ideas are theoretically interesting but I presume you have a need at hand.
simple way: router and a fence
Not much harder way: fence and a chisel. I watched Will Neptune accomplish this feat to make a tapered dado and it went surprisingly quickly. The secret to doing it quick is the chiseling technique which I will try to explain.
In the picture I am making a dado into a dovetail socket, but the technique is the same. The tip of the chisel is used to shave about 1/8" portion of the stuff to be removed. Start with angle cut but as soon as practical transition to downward thrusts of the chisel that make an arc path. You will soon get the feel for how much can be removed with each arcing thrust of the chisel. It takes not a minute to travel the 3" depth of this dovetail socket.
Re: widening dados
Re: widening dados
Andy Lincoln,in Dearborn MI
Jerry,
A side rabbet plane would work in this instance.Big difference though in cutting the poplar vs plywood.
How about a small rabbet on the plywood going into the dado?I'd bet that you have something on hand that
would make it possible,neat and efficient.
Andy
Re: widening dados
Agree, and
Wiley Horne--So. Calif.
knife the line first to avoid splintering the ply. Otherwise, what Bill T. said--fence your chisel.
Wiley
Re: widening dados
Re: Solid Advice, but Bill...
TomD
wasn't it you, who a week or so back was wondering who needed a wooden block to guide a chisel while dovetailing? And is that a massive slab of bench top you are working on there?
Re: widening dados
Jack Guzman from Maine
Me too
I have been using my 79 for just that job for years and it's quick and easy to creep up on the right width. I never needed anything else.---Jack
Re: widening dados
thanks all
Re: widening dados
Bill Tindall
You just noticed that it is thick (2 7/8") !?! A quick check revealed that I have posted 28 pictures of making stuff on this bench over the years. It was constructed from some 12/4 poplar I had left from a special order of 12/4 for a customer. The lumber was 14' so the bench became 7'.
Similarly, and to clarify, the technique for constructing a chest of drawers with housed dovetails has been previously posted several times as part of discussions on these projects. In spite of the fact that I have done dozens of these sockets I would have difficulty judging 14 degrees without the guide block. But for 0 degree cuts where undercutting a degree or two is desirable I do not find a guide block necessary.
