New WoodChat!
Narex chisels, Cr Mg steel and isothermahardening
Patrick Gibbons
This website has a nice explanation on Isothermal hardening used with Narex chisels.
Re: Narex chisels, Cr Mg steel and isothermahardening
Patrick Gibbons
The website should be www.narexchisels.com.
Where have I seen this shape before?
Bill Tindall
These chisels look strikingly similar to the new LV chisel shape. Has anyone used this chisel brand?
The steel section states that the edge will get better after the first 1 or 2 mm of heat treat damage is ground off. Seems the manufacturer should be doing this step before sale.
Re: Where have I seen this shape before?
Warren in Lancaster, PA
Lee Valley was selling Narex chisels while they were designing their own chisels, so it isn't like Narex was copying LV.
John in NM
On a $40+ chisel I would certainly expect it. On a $10-$12 chisel? No way. I'm a confirmed cheapskate, as such I don't mind doing a bit of grinding I would do anyhow. I expect the average, non-obsessive user won't bother grinding through the softer stuff, I doubt I would.
I've heard good things about Narex, but I never seem to get around to buying a couple - probably because I don't actually need any new chisels. My favorite .22 was made in Czechoslovakia in the 1950's and the same basic design is still in production today. If the Germans had succeeded in keeping the place, I bet that same stuff would cost 5x :D
Glad they didn't - for many reasons
I have some narex chisels
Lars Parrington
Cool link! In my head I had equated Cr Mn with the Chrome Vanadium used in cheap socket sets. Good to know I was wrong.
I have some narex bench chisels and also a few of their mortise chisels. The only other chisels I can compare them to are a motley collection of old socket chisels. I haven't done any rigorous testing, but I do feel that the narex steel dulls somewhat quicker than the socket chisels. I have honed them less than 10 times, and never ground them, so there's a chance I'm still within the softer steel region.
I don't wish to come across as too negative. These chisels work fine and get the job done. I would purchase them again.
Re: I too, and not bad
Bruce McCrory
I have a bench set, from Highland. They have been working great for me. I am looking at the mortise style at LV--for handle color difference.
The manufacture is metric, so we with English brains may grumble. 3/8" is a sloppy fit in a 10mm mortise, so I suppose someone could shave 1/64 off the chisel. Or, just throw away the ruler at this level of hackery and go commando.
This is what bugs me
Patrick Gibbons
I think the hornbeam handles on their premium line look to be more comfortable than their regular handles but I would have to have imperial sizes. Metric equivalents don't work for me, though a few of the metric sizes would be good because they are inbetween sizes. As inexpensive as the true-sized Lee Valley versions are, one could buy them and rehandle them. Of course I'm going by looks only. I may find the LV Narex handles just fine. This is all moot. I don't need new chisels. I just want them and about two or three dozen other new tools. If I were just starting out again these would be top on my list because they get a lot of things right at an easy price.
Re: This is what bugs me
Bruce McCrory
I don't think the LV versions (bench and mortise) are milled to imperial dimensions, even though noted at 1/2", and so. If they are manufactured thus, fantastic! I would definitely verify before buying.
LV Narex chisels...
Rob Lee
Are all ground for us to Imperial sizes. We also select whichever handle we find best suit the chisel.
Cheers -
Rob
metric or not...why important
Bill Tindall
I have never encountered a situation where I needed a chisel of some precise English or metric size. Where is it important whether a chisel is metric or not?
Without measuring them I could not till you what the sizes are in the chisels I made. They are neither English or Metric. They are about something, and chosen to be about right for chiseling the task at hand.
Re: LV Narex chisels- Accurate big print too
Bruce McCrory
And, verified! Thanks,
Re: metric or not...why important
Darren Brewster
It is convenient and a time and headache saver when your chisels are the same width as your plow blades.
Bruce McCrory
I have to agree, plus or minus....
I think it was an earlier post that I mentioned tossing the ruler (go to marking gauge) at this level. However, possibly resulting from my profession when dealing with WAG subcontractors who didn't read, "follow the numbers" was my mantra.
So, I have a 3/8 mortise chisel. Do I clean up with a 10mm bench chisel that is roughly 1/64 bigger? My tenons are all cut for 3/8. Given my habits, I think I should grind a few metrics to match imperial.
I knew those sharpening stones the chisels (at ~3/8) were ordered with weren't such a bargain. That's good business management, Mr Lee.
Bruce, a MN Galoot
I think it's easier to clean up mortises with chisels that are smaller than the mortise chisels (or router bits) anyway. Otherwise, you have to watch both sides of the chisel all the time.
Re: metric or not... Because
Patrick Gibbons
As others have stated, I want my tools to match so there are no surprises. Plow a 3/8" stopped groove, and use a 3/8" chisel to finish the stopped end. Or have both iron and chisel be metric. But not one metric and the other imperial. Since my lumber store doesn't sell wood in metric sizes then imperial sizes are called for from the beginning. If I buy 3/8" thick wood, I'd like to have tools sized to handle it. That's another reason plywood can drive me crazy. Of course you can work around it but why introduce another possible stumbling block? I make enough problems on my own without needing help. However, most of the time it's no big deal. Others have stated they like to use chisels that are slightly smaller in some situations. I agree and that's why I'd like to have some oddball sixteenth sizes (3/16, 5/16, etc).
Same for me...
John in NM
I guess mine are metric, being Swedish or whatever. Never measured, never cared one way or the other. Simply is not relavent to the type of work I do and have done.
Clearly, I do not use plows :D
come to think of it,
Bruce, a MN Galoot
I don't know what my chisels measure, either. They either work or not. Come to think of it, most of my chisels are Swedish, but then part of me is, too. Maybe there's a trend here.
