New WoodChat!
looking for info on manual drill press
Edward in Vancouver
Picked up a "manual" drill press today, about 12" tall with a big-a** handwheel measuring 5" across on the top. The quill only travels about 1 1/4" and the chuck and table were missing.
A 1970's era jacob's chuck from a B&D hand drill fits the quill perfectly, but I have no idea what the table originally looked like.
I can find no markings on the drill, frame is cast iron, and the gears are very similar to my MF eggbeater drill. Someone decided to paint the body black and the handwheel red, the gear wheel wasn't painted and is faded orange, but I don't know if it was red originally. The drill doesn't clamp on a bench but has two screw holes in it's casting to be permanently mounted.
I'd like to rebuild this thing and use it, but I have no idea what the table looks like. There is also noticeable slop in the quill where it exits the last surface of the main frame. It is possible to shim this with brass?
Edward
Re: looking for info on manual drill press
TomD
What brand is it. Do a google image search, even without the name, and you should get a lot of info. If that doesn't work, I can post whatever you have, preferably a picture on a machinist forum for you.
Edward in Vancouver
That's just it.
I've been looking at a MF ca. 1925 catalouge and it isn't there. I've been looking at Goodell Pratt catalouges,and it isn't there either. Those are the only two mnfctrs that I know of, other than craptsman which in any case would have been one of the two. Did Stanley make drill presses?
This one has a cast frame, and is mounted onto the bench with screws--no clamp. It is single speed and advances automatically--no lever to press down. The flywheel is cast and about 5" in dia. but shaped like a hand-wheel--rounded polished edges and spokes. The chuck is missing which probably would tell me a lot more, but the quill is threaded to take a modern chuck, so I am guessing American, but it could very well be English.
I'll see if I can post a pic tomorrow.
Edward
Re: looking for info on manual drill press *LINK*
Bruce, a MN Galoot
I can't believe I beat Bill H to the punch on this one.
First (and last), join the Old Woodworking Machines forum and post your question there. That's the function of that forum, and there is most assuredly someone there who knows the answer to your question. There is also a very large database of information on all sorts of great old machines.
OWWM
OWWM focuses on powered machinery, but there's a secondary forum named SWARF* that will permit your questions. If you've got access to a digital camera and a photo hosting site like Photobucket (can be a friend's site, if s/he is willing to let the photos get loaded to the forum), that will help a lot in identifying it.
There were multiple brands of post drill - not sure if that's what you've got - and, if it's a bench model, I think there were multiple models of those, too. Certainly, North Bros. (not owned by Stanley until 1946, way past the heyday of hand-cranked drill presses) had some.
I have this vague, back of the brain feeling that there's a site on this type of drill press, but it's too far back for the search and rescue dogs to find it.
*"Stuff Without Arn Related Facts," "arn" being the forum nickname for "iron," as in "lots of cast arn in this old machine."
And, no fair, Bruce! You live two hours ahead of me!
Bruce, a MN Galoot
Notice the time of my post, Bill. It's one of the only advantages of night shift :D
TomD
There are lots of old machinery manufacturers, including ones in Ontario, and probably other places, that one has probably never heard of. That is why when I have an oddball, I just do an image search. You will get hundreds of pictures of the category, and you will either find your drill, or one very like it, which presumably is the point since unless you get super lucky on parts you are presumably going to recreate your part as an approximation?
Options for your bearing would include stuff like an olite bearing, or maybe even babbit. If you need some machining, let me know, I am pretty limited in what I would take on, mainly because I don't stock a lot of metal, but I do have the machines for it.
Bruce, a MN Galoot
Babbitt bearings on a machine are not a second-class solution, either. If they're good enough for a 750,000 HP generator, they're good enough for a drill press.
Just be sure to keep them oiled
Edward in Vancouver
Thanks for all of the information!
I took a beverage with me into the garage and had a real long look at this thing.
I'm pretty sure it's not M.F. but it sure looks like a Goodell Pratt. Matter of fact it looks like a #8 "bench drill" but with, ummm..."modifications"
Mine is screwed onto the bench. But when I look at the holes for the screws, one is 1" away from the edge of the casting, and the other is 3/4" away from the casting. Neither are countersunk, but they are drilled square and clean. I'm figuring either the thing fell off the bench and broke, or the clamping portion of the casting was deliberately cut off. The whole frame has a "bead" or edge around it, but this stops where the base is screwed onto the bench. The cutting of the casting was done clean and neat though.
Mine has no names or model numbers cast onto the frame. On the G-P catalouge the name is clearly cast onto the side of the frame. I really doubt someone would take the time to grind off the name on the casting.
My crank is cast iron and has a pattern of dots all along it's surface. It's fastened to the shaft with a square ended. The same style of bolt is used to hold the (missing) table in place--No thumbscrews, square ended bolts.
Mine has this "thing", an oil spout, sticking out of the main bearing directly under the hand/flywheel. Massive really, looks like 1/4" nickel plated tubing bent up like an ear-horn. My fly wheel looks at lot larger than illustrated, and nicer too.
Someone painted this thing a while ago with a spray can and while it works, it moves stiffly. If I hold the fly/handwheel so it doesn't turn while I crank, the quill advances, if I let the wheel spin, the quill doesn't advance. Total travel of the quill is 11/4". It might be all gunked up, I have no idea of how to take this thing apart--yet.
Edward
