New WoodChat!
Modular Sticking Board
William Duffield
Inspired by Matt Bickford’s Mouldings in Practice, from Lost Art Press, and a couple of recent jobs for custom architectural mouldings, I decided it was about time I stopped kludging together a new sticking board every time the height, width or length of the needed moulding changed. I also wanted a sticking board that I could reconfigure without tools, and that would not be degraded by reconfigurations (as would happen if it were assembled with screws or nails). To accommodate longer runs of mouldings, I needed a sticking board that is longer than my workbench.
This is the modular sticking board that I designed and built. For its construction, I used the Festool Domino joining system, which is quick, accurate, and it makes sturdy, precise joints that are quickly and easily reconfigured. I suppose doweled joinery or even KD fasteners could be used in place of the Domino mortises and tenons, but the appliance would not have been as accurate, or as quickly constructed.
My sticking board is made from four pieces of four-squared tulip poplar: a base and three fences, a handful of beech tenons, and another handful of flathead wood screws. Using a countersink, I installed a row of five wood screws in each end, to accommodate various fence positions and moulding widths, and so I could plane in either direction. The base and fences are finish jointed and planed to a thickness of about an inch. The fences are about an inch and an eighth wide, and the base is about four and a half inches wide. None of these dimensions are critical. Just use the straight lumber you’ve got available, or even some plywood or MDF (a.k.a. termite barf).
My bench is about 7’ long, with a patternmaker’s vise on one end, so I can fit an 8’ sticking board between the planing stop on one end and a dog in the fully opened vise.
At several locations (four) along the length of the base and fence, I cut mortises in the base and fences. A column of five mortises in the base allows the fences to be adjusted for the width of the moulding. Two of the fences have a mortise on the bottom and on the top surface, and the third fence has a mortise only on the bottom. This allows one, two, or three fences to be stacked to accommodate mouldings of different heights. The fences can also be moved closer to or further from the front edge. Three heights by five horizontal positions accommodate fifteen different moulding sizes.
The m&t in the top of the first fence and bottom of the second fence are offset a couple of inches along the length of the sticking board so that the tenons would not interfere with the tenons above or below, because the mortise depths turned out to be just a little more than half the thickness of the fences.
I also implemented an alternate mounting method, to clamp the sticking board to the front edge of the bench instead of at both ends. It uses the Domino again and Festool 489570 Quick Clamps. Alternative strategies would include drilling half inch holes with a drill press or brace and bit, and modifying a cheap F-clamp with a grinder to fit the hole. I used a 14 mm mortise cutter in the Domino. If you only have a DF 500 with a 10 mm cutter, you’ll need to adjust the fence and punch two partially overlapping mortises, one above the other.
Re: Modular Sticking Board
Bill Tindall
Would you include a picture of how it is used. I have no idea what it is for.
William Duffield
It's used for creating moulding, using hollows and rounds, rabbet planes, etc., or complex moulding planes. It supports the small cross section moulding stock on the bottom and side so that it doesn't bend while planing it. Roy Underhill does a much better job of describing and demonstrating this than I ever could.
http://www.pbs.org/woodwrightsshop/video/2900/2913.html
In the Woodwright's Shop episode at the link he uses one to make sash. The specialized sash sticking board is much more complicated than this one.
The appliance is also explained in Appendix 3 of Matt Bickford's Mouldings in Practice.
http://www.lostartpress.com/Mouldings_in_Practice_p/bk-mip.htm
Re: Survey
William Duffield
The silence is deafening. Lots of people looked, but few replied. Looking could easily be attributed to the "Picture Worth a Thousand Words" syndrome. Obviously, many of us, like Bill Tindall (and myself), have a hard time breaking our power tool addictions, and thus might not find much value in making mouldings with hand tools. Others only build works in the Shaker or A&C traditions.
Thus, this survey in five parts. If you answer "No" to any question, you need go no further.
0 - Do you build furniture? :O
1 - Do you making furniture in a style that requires complex mouldings?
2 - Do you use hollows and rounds, rabbet planes, side beads, side rounds, snipes bills, complex moulding planes, etc., to create the mouldings?
3 - Have you found antique planes to work well enough, or do you use new moulding planes that you have built or purchased for this purpose?
4 - Do you use a sticking board when sticking the mouldings? Do you build a new one every time you need to make a new moulding? (Warren has already said, "Yes.")
5 - Do you follow Musings from Big Pink or have you read Mouldings in Practice by Matt Bickford?
Re: Survey
Larry Barrett
William, I think your sticking board is quite clever. I read Matt's blog, bought a half set of H&Rs, partly as a result of a request to produce some picture frames. I later bought Matt's book and will make a sticking board soon, having discovered how awkward it is to make picture frames without one.
Re: Survey
Tony Wilkins
I too thought it was very clever. Someday I want to make my own moldings but have to learn to make the furniture first ;)
Re: Survey
It would be helpful for me to see it in use - even if a mocked-up use. I'm puzzling over, for instance, how you would deal with moldings that are smaller in section than your side pieces; what you do for a stop on the groove you've made, to keep the molding from sailing away; things like that.
The one and only sticking board I've made was for an existing molding that needed reduction in one dimension (new glass in a passage door was unavoidably thicker than the old), and that molding was about 1/2" by 1/2" - not sure how your surely quite clever multi-use board would work with that, and eager to learn.
Re: Survey
Bruce, a MN Galoot
I wouldn't call my power tool use an addiction, but it is the easiest path to do what I do. I have two routers (one recently acquired) and a router table. I don't tend to make furniture that requires moldings, except once. But I do make picture frames, a fair number of them.
I also don't have any dedicated molding planes, but I do have a Stanley 45 in moderate condition. Unfortunately, the blades that came with this contraption are either sash-making blades or various width straight rabbets. For reasons that I can't explain, I cannot make this thing work very well. I suppose if I lived in an area with a greater abundance of old molding planes it might be easier to find profiles I need, but I don't. Thus, it's a lot easier to trot on down to the nearest Rockler store and pick up a new router bit. Or just make do with the ones I do have.
I have made a variation of the sticking board you posted, but it has a different use for me.
I don't read either of the blogs you cited. Heck, I don't read any blogs.
Re: Survey
Bob Entwisle in NJ
Hi William,
Please don't take the silence, (on my part at least) as an indication of no interest in the subject.
On the contrary, I am very interested in the subject, and your post of the adjustable sticking board caused a flurry (for me) of further digging.
I can not say that I have made any complex moldings, only simple profiles, most of those simple flat beveled styles etc. The Roy Underhill video was excellent in demonstrating the need for and use of a sticking board.
For me the demonstration of the use of a sticking board showed me how I might go about a more complex profile.
It is astounding how much of woodworking boils down to workholding methods and techniques.
Please keep posting this sort of thing, your generosity in sharing your experienced expertise on these subjects is greatly appreciated!
Bob in NJ
David Barnett
(Message Deleted by Poster)
it was "plane" to see
Bruce, a MN Galoot
you couldn't resist the opportunity to "snipe, Bill." :D
Re: Survey
William Duffield
It'll take me a bit of time to get out to the shop and set it up to take photos of the process of sticking mouldings. The shop is currently configured for other operations. I should have taken pics of the last job I did, but didn't think about it at the time. Don McConnell's DVD is very useful, and he's a lot better at explaining what's going on than I am. The sticking board is used to push back against the plane, both from the bottom and from the far side. The fence is adjustable horizontally just to allow you to get your weight over top of it for narrow moldings. The fence is adjustable vertically so that it doesn't interfere with your hand on top of the plane. Since the plane is a few inches high, the fence doesn't need to be no higher than the moulding, just not much higher. One or more of the FHWSs set in the end of the board are adjusted upwards so that the moulding hooks into their sharp heads, to keep the moulding from shooting off into space. You push forward with the plane; the screw pushes back. They are NOT for screwing the shooting board to the bench.
I'll try to respond to the other survey posts tomorrow, assuming that life doesn't get in the way again, as it did today. First, I activated the brake on my SawStop, and had to take a couple of hours to run over to Delaware to get another one, and a new Freud Fusion blade to replace the one the brake cartridge ate, to boot. When I got home, before I could finish installing it, the bench dog informed me she had lost an argument with a skunk. I had to run into town to get a quart of peroxide, and then deactivate the skunk.
Re: Survey
RonHarper
I am starting down this road. I believe I have enough skill with the tools to follow Mr. Bickford's very clear instructions. I have a sticking board pretty high up on my things to do for the shop list. Don McConnell and Ralph Brendler both did demos in my shop for Hoosier Galoots and I really believe this is very do-able
