New WoodChat!
French Polishing - Primer
Guillaume Dery
French Polishing Primer
1 Introduction
French polish (also known as piano finish by some) is basically a brushless method of applying shellac to obtain a perfectly smooth very high gloss finish. Contrary to what you may have heard, the technique is not magical nor that difficult if you pay attention to details and follow the basic steps.
Why shellac? It is the safest finish I know of (next time you eat a shiny candy or take some coated medicine like Advil, know that the outer coating is shellac), it is easy to prepare and apply, gives wonderful depth to your finish and requires no special setup or equipment. Not to mention that it is reversible and repairable and that the different kinds and grades can be used to impart tone to your woodwork. Finally, it is one of the best sealers around. It can be used to seal knots so they don’t bleed and to use between incompatible finishes (e.g. water-based over oil) if one uses a de-waxed variety.
How does one French polish? French polish consists of the following steps, which I will explain in greater detail below:
• Material (supplies) Preparation
• Stock Preparation
• Bodying & Spiriting-Off
• Glazing/Polishing
2 Materials
The materials listed below are all that are needed to lay down a great finish. Some are optional depending on the steps you are taking, these are shown in italics:
Consumables
Shellac
You can either buy the canned stuff or prepare your own by dissolving flakes. Colour makes no difference (use super-blond, blond, garnet or orange as is needed for your piece) nor does grade up to a certain point. It should be mentioned however that although one can quite adequately use any shellac for French polishing, the best gloss and uniformity of finish is achieved from de-waxed shellac.
Personally, I prefer to dissolve my own flakes as I know how fresh the batch is and have complete control over all the variables in my finish
Solvent Pure alcohol. Really, any type will do. This is used as the shellac solvent, to dilute the finish and to spirit off. Even though some people will say that some alcohols are better than others for shellac, this is mostly due to drying time (and toxicity for methyl hydrate). This is an issue only with brushed finishes. As we are not brushing and the shellac melts into the previous applications and goes on smooth, we are not concerned about a solvent which may evaporate too quickly. I have been known to use pure rubbing alcohol which could be purchased at Ritchie Seed and Feed in gallon quantities (it is used to rub down horses) to good effect.
I cannot stress enough that it has to be pure (about 99%) anything less means that there is water mixed in and it will cause finishing issues and give you no end of grief. A side note to that effect is that alcohol has a love affair with water and will quite happily absorb ambient moisture. If you are not using it, please put a cap on it.
Oil Oil is purely used to lubricate the rubber to prevent sticking and migrates upwards until it is spirited off. Any pure oil will do. I have a fondness for raiding my kitchen for my virgin olive oil. It is one less consumable I need to keep on hand in the shop and the quantities used are minute.
Grain Filler If needed. There are many methods of grain filling. I will gloss over some of them in the material preparation section but as this is a presentation/handout on the polishing, it will be cursory at best. Suffice it to say that, if needed, you can use commercial grain filler, pumice or epoxy. I tend to favour the latter 2 options (epoxy being the quickest and pumice the more traditional).
Glazing compound If needed, automotive rubbing compound can be used after finishing to bring the surface to flawless regularity and shine. If you are going this route, please make sure that there are no nasty additives like silicone in the compound as they will make repairs etc. damn near impossible.
Pumice FFFF pumice is used as a grain filler and mild abrasive to level the finish if needed.
Epoxy If needed, 5 minute epoxy is a quick, durable and worthwhile alternative to pumice for initial grain filler.
Odds and ends
Containers For holding and dispensing the mixed shellac, alcohol and oil as well as a seal-able container to hold your rubbers (no snickering please). I am partial to the cheap ketchup/sauce dispensing bottles you can buy at the dollar store to hold my shellac and spirits and to mason jars to hold the rubbers.
Measuring cup For measuring alcohol or pre-mixed shellac for diluting
Scale For weighing shellac flakes and/or buttons for dissolving
Mixing cups Optional, for mixing epoxy filler
Tack cloths Tack cloths are a godsend for really removing the dirt and dust from your piece prior to finishing.
Latex Gloves Not strictly needed but appreciated by the fastidious or if you are using different colours of shellac, etc.
Muneca (i.e. the rubber)
Cover
Good lint-free soft cotton cloth for the outer covering (my #1 choice is old white undershirts, followed closely by old bed sheets which have been deemed surplus by SWMBO,). Please make sure to use white cloth or, at a minimum, that the colour does not bleed. I’ve heard that that is extremely annoying...
wadding Preference given to wool material but pure cotton wadding can also work quite well. My preferred wadding is thick wool felt if you can find any. We are looking for absorbency and flow control first and foremost
3 Material Preparation
3.1 Shellac
Using whichever grade/colour of shellac you prefer, prepare a 2 pound cut batch of shellac. Please refer to the cheat sheets at the end of this article for ratios. Note that to work from dry shellac (flakes or buttons), it is a weight/volume ratio (shellac by weight and alcohol by volume) and a volume/volume ratio for pre-made shellac.
In order to control all variables, I strongly encourage dissolving your won shellac. You are guaranteeing that there will be no additives and that the shellac is as fresh as can be. Any shellac which has been prepared too long ago will not dry properly. Only make what you need. Additionally, shellac flakes have a much longer shelf life in the back of your fridge than dissolved.
If you must use commercial shellac, the Zinsser comes in a 3 pound cut which you will need to dilute. Also, in the Zinsser brand, only the “Seal Coat” is de-waxed FYI.
Shellac flakes will generally dissolve in 24 hours. Place the appropriate weight of flakes in a sealable jar and add the appropriate amount of alcohol. Seal the container, give it a shake and wait a day, shaking occasionally. If one is really in a rush, the dissolution process can be accelerated by grinding the flakes in a coffee grinder and by gently heating the solution using a bain-marie (double-boiler for you Anglophones).
Note: Although one can certainly use a paint strainer to remove impurities, this is unnecessary for French polish as the muneca cover will act as a strainer and prevent any impurities from reaching your work.
3.2 Muneca (AKA the Rubber)
The essential tool of the polisher. You will probably end up with several sizes in multiple quantities to handle different colours and grades of shellac as well as different sized items.
Although the traditional shape is somewhat shoe-like (a rounded triangle) to assist in reaching corners, I have a preference for rounder rubbers and just use smaller ones for hard to reach places. Start by preparing the wadding (using your material of choice) by repeatedly folding in the material until you have achieved the desired shape, at a thickness of approx. ½” and with a smooth and well rounded bottom. If using a gauze or cheesecloth as wadding material, you may want to add loosed cotton batting as a core to assist in achieving the desired shape and act as a reservoir for the finish. This wadding can be kept and used almost indefinitely even though you will change the coverings as they wear out. Even dried wadding can be revived by saturating with alcohol. One then deposits the wadding onto a pre-cut square of covering (approx. 5” X 5”) draws the ends up with a bit of twist, ensuring that the bottom of the rubber is perfectly smooth and has no folds or irregularities and presto, you have made a rubber.
Please note that the covering must be a soft, lint free piece of cotton and that absolutely no seams must run through the application surface (the bottom).
N.B.: Munecas are always loaded from the inside. Whether it be alcohol or shellac, you peel back the covering and load the wadding directly. The only exception to this is the lubricating oil, a drop of which is added to the outside of the cover as needed.
4 Stock Preparation
Before we begin the process of French Polishing the piece, we need to ensure that the surface to be worked on is a near flawless as we can make it. This means that the surface must be dead flat and smooth.
I will omit, for the sake of brevity, the visual inspection, ironing out of dents and scratches, etc. and assume that everyone can get their work to this stage.
By its very nature, French polish does not lend itself well to open-grained woods such as oak or ash unless much care is given to grain-filling beforehand. Additionally, any other finishing steps which one may wish to take should be completed as well prior to beginning the polishing process. That is to say that the piece should be stained, oiled (if desired to pop the grain or mellow a look), the grain filled and the surface sanded or otherwise smoothed out.
4.1 Grain-filling
There are, I am sure, more ways to do this than I can shake a stick at. As this handout is about French polishing, I will stick to describing the 2 that I have tried and that work for me. They are epoxy and pumice.
N.B.: If you are using pumice as a grain-filler, you will need to seal the surface with a spit coat or 3 of shellac prior to grain-filling. Disregard for epoxy.
4.1.1 Epoxy grain-filling
This is the most fool-proof and easy way to fill the grain to have a level playing field to apply the shellac to. Mixing small quantities (you need to work fast) of epoxy (5 minute epoxy works great for me), you spread the epoxy with a scraper or utility blade that has had the corners eased so as not to dig into the wood and work it in by scraping against the grain. Remember that you are not trying to coat the wood but rather only to fill the grain. Once the epoxy has set, move to another section of the piece and repeat the process. It is important to keep it thin and allow some setting time so as to not have an ungodly mess on your hands. You should overlap your sections some in order to ensure complete coverage. Once the epoxy has cured, sand the entire piece down until it is smooth and remove all the dust (tack cloths are your friends).
N.B.: In most cases, if the piece is to be stained or dyed, you will want to do this before the epoxy grain filling as the light and dark areas or the grain would reverse due to the epoxy’s low absorbency.
4.1.2 Pumice Grain-Filling
Once a seal coat of shellac has been laid on and allowed to dry for a few hours, we can begin the grain-filling process. Please note that grain filling with pumice can be done at any point during the finishing process up to the final “coat”. This will be advantageous as building up the finish will tend to show some flaws which were invisible previously. If the pores of an open-pored wood are not filled properly the finish will slowly shrink back into the pores. The result will be thousands of tiny craters in your finish.
The actual pumicing procedure is simple and is as follows . . .
• Load your rubber with pure alcohol (make it as wet (loaded) as you would with shellac). Same as with shellac, you will reload it when it becomes too dry. The alcohol helps to dissolve/soften the shellac as well as to clear the pumice.
• Sprinkle the pumice to be used on a clean sheet of paper.
• Pick up some pumice with the loaded rubber (just tap it down on the pumice)
• Add a few drops of alcohol to the outside of the rubber and rub it around until all the pumice is clear
• Using firm pressure and working on a small section at a time, rub out the surface (using the same type of pattern as for bodying up) until the grain and pores are filled.
• Repeat and reload until done.
• Finish by cleaning the work by adding a new cover to the rubber and adding alcohol. The alcohol and cover should pick up any stray pumice. This is to be done when the grain-filling has had time to dry properly (so as to not undo the work you just put in filling the grain).
Please note that due to abrasive action, this will probably abrade through the cover of your rubber. Replace the covering before it is worn out so as to not contaminate your core with pumice. You should have a stock of pre-cut covers ready to go, both for grain-filling and for actual polishing.
4.2 Sealing
This is the initial base coat upon which we will build the French polish. It also serves as a base for pumice grain-filling as well as to ensure that there is no colour bleed from different-coloured woods or from stained areas, inlays, etc. For the above reasons, thought should be given to using light (bleached or super-blond) shellac if light or contrasting woods are used.
The first step in sealing is to seal any transitions (areas with changes of material and/or colours). To do this, take a clean square of covering material (you did pre-cut a bunch as mentioned earlier didn’t you?) and fold it into a smaller flat square. This cloth is then saturated in our shellac. Not take this cloth and in one smooth straight motion go over (along not across) a transition area. As your cloth will pick up wood oils or stains/ etc, fold over to an unused area and repeat the above. Repeat this process, always using a clean area of cloth, until all transition areas are sealed. If a large area of a different colour than the main body of the workpiece remains unsealed after the transition, fill this area with a seal coat, ensuring to start and finish within the boundaries established by sealing the transitions. A single area of cloth can be used for this as contaminants will not be picked up. Any of the cloths used above can be used to fill the main (darker) body of the piece prior to disposal.
Repeat the above process 3 times to ensure an adequate sealing of the work.
N.B.: It is important to change cloths regularly and always use a clean area to seal transitions. Failure to do this can lead to bleeding. Cloth squares are essentially free… your project, not so much so…
Also of note, if your project is of a uniform wood and no pumice grain-filling required, the sealing step can be omitted and you can jump right into bodying up.
5 Bodying Up
5.1 Definition
Bodying is nothing more than the process of building up a finish to an adequate thickness for its intended purpose. In the case of French Polishing, this is accomplished by laying it on via a rubber, in a number of sessions. Although 100s of passes will be made, this does not result in distinct layers. The shellac melts into the previous work, resulting in a single thick coat of shellac.
5.2 Process
One does the entirety of the bodying up with a 2 lb. cut of shellac (as is all else covered here unless specifically noted otherwise).
• Load the rubber wadding with shellac and install a new cover. Tap the reassembled muneca against your hand or a clean surface to distribute the finish. Blot on a clean piece of paper to test the loading.
N.B.: A rubber should never be sopping wet but rather hold and flow out shellac through finger and hand pressure. The blot test will reveal how adequately loaded it is (the shellac should appear as individual dots against the paper)
• Glide the rubber onto the work and begin laying on the shellac in circular and/or figure-8 motions. It is important that the rubber glide on and off the work (think of an airplane taking off and landing) and never cease moving while on the piece that you are finishing. When in doubt, gilde off in order not to create ridges or otherwise gum-up the finish which would require sanding and starting over.
• Although one should not maintain a death grip, pressure is key to building up a good finish and to ensuring its final hardness as well as to control flow out of shellac. If your knuckles are white, you are pressing to hard. Start with light pressure and gradually increase pressure until you see the finish lay on and a smeary smudgy look following your rubber. This is an indication that you are getting adequate pressure and that shellac is flowing out at an appropriate rate.
• Continue laying out the finish using increasing pressure to maintain flow until either the muneca is running dry (no more smear following) or you start to feel the rubber sticking to the workpiece. In the latter case, apply a single drop of olive oil to the outside of the muneca for lubricationand resume laying on finish. If the former, reopen the muneca and reload your wadding. Apply the drop of olive oil to the outside of the rubber.
• Occasionally pull-over the finish, that is to say, switch from circular or figure-8 patterns to straight lines (glide on, glide off Daniel-san) to even out the finish.
• Please note, the oil is strictly a lubricant and adds nothing to the finish so limit its use to a drop at a time only when needed.
• It should be noted at this point that most polishers observe uneven buildup of finish. That is to say that the center of a work builds up much quicker than the edges and corners. The fix to this is simple: Work and pay attention to the corners and the center will take care of itself.
• End the bodying up sitting by spiriting off the work prior to setting it aside.Load the rubber with pure alcohol and polish as above although oil should not be needed to lubricate the work. Ideally, one should be albe to exert more pressure at this step than in the actual bodying.
Dealing with curves
Carvings and complex mouldings in furniture present a special challenge as they cannot be adequately polished with a rubber. Shellac should be thinned to a 1 or 1.5 lb. cut and applied to these with a fine soft brush (camel or badger). Multiple applications are preferred to a fewer thick and wet applications. Once dry, the high points should be glided over by the rubber to ensure evenness of shine with the rest of the piece.
How long is a sitting? As a rule of thumb, you should have gove over the entire surface about 3 times. Although we want to build the finish up as quickly as possible, we do not want to run the risk of putting on too thick a coat which would lead to finish issues due to uneven drying.
Once the finish has been allowed to gas out for at least an hour, repeat the spiriting process, using only straight strokes with the grain. This builds shine and hardness as well as removing any excess oil which has been left on the surface.
6 coats or sittings should build sufficient thickness of finish for furniture work
Optional step:
Once the bodying up is complete, and prior to glazing, the finish can be levelled using wet-dry fine sandpaper (800 grit) to ensure perfect smoothness, prior to glazing. A light touch is key as the goal is only to remove surface imperfections.
6 Glazing
Once we have built up sufficient finish thickness, we are ready for glazing. This is strictly speaking, refining the finish to achieve perfect level, fill in minute scratches and achieve the high gloss typical of French polish.
Glazing is done with thin (approximately 1 lb. cut) shellac. Rather than dilute a new batch of shellac and use a different rubber, we will use the existing rubber and shellac cut and just add alcohol when loading the rubber. Load the rubber with ½ the amount of shellac that you would typically use for bodying up and add an equal amount of alcohol. Finally, install a fresh cover on the rubber. As always, distribute the finish and do the blot test.
Starting in the middle of panels and working your way out towards the edges, glide on and glide off the pad (using a drop of oil for lubrication). This is typically done in straight lines, along the grain. Circular motions are only used to deal with problem areas and should be pulled over in a straight line following rectification. Essentially, glazing is the same as spiriting off but for a different reason. More pressure is used in this step than any previous steps and the rubber should be somewhat drier.
Continue and repeat the above until the entire piece has achieved a uniform blemish-free shine (you can re-glaze specific problem areas discretely). If any finish flaws are discovered and addressed at this stage, panels should be re-glazed in their entirety once the issue is rectified.
Finally, after the glazing has been allowed to dry for a few days, and purely optionally (I never bother), the entire piece can be polished using an automotive glazing compound to remove any residual oil traces and achieve an even higher shine.
Shellac Cheat Sheet
7 Dissolving shellac
A pound cut refers to 1 gallon of alcohol for 1 lb of shellac. Increasing the cut proportionally increases the amount of shellac flakes as shown above.
8 Thinning Shellac
To convert remixed shellac to a dilute cut, add the appropriate amount of alcohol, as shown in the chart. For example, to convert a 2-lb. cut to a 1-lb. cut, add 2/3 of 1 part alcohol to a 1 part existing 2-lb.-cut shellac solution.
Re: French Polishing - Primer
Guillaume Dery
Sorry gang, no pics yet. I got too busy actually doing the demo/seminar yesterday that I forgot to ask anyone to snap pics. Will do some at home and edit the article. Please feel free to point out any omissions . This was the handout I wrote for yesterday and I am sure that there are areas I forgot to document and/or glossed over.
Cheers,
Guillaume
Chuck Bjorgen
Well, that's just plain terrific information. When I was a teenage kid 60 years ago I spent a lot of time in my folks' basement trying to figure out how to achieve those mirror- like finishes. Great for the articles section. Thanks.
Thanks, nice post (and, I hope, future article)
I'd never heard of epoxy as a grain filler - intriguing.
