New WoodChat!
New Marking Gauge
New Marking Gauge
Robert Tutsky
New Marking Gauge
Robert Tutsky
I was forced to move 3 years ago and had to sell all of my woodworking equipment I had at the time... a most painful experience. Now I want to start woodworking again albeit at a smaller scale (I like making smaller things anyways). I've managed to pick up a group of tools to start with but one thing I missed was my marking gauges. Rather than buy one I decided to attempt making one. It's a gauge that has a dual purpose. Here's what I finally came up with...
A narrow gauge that fits my hand ergonomically and is also a compass. It can scribe a cut line or a pencil line. I paint watercolors and a marking gauge that scores a pencil line works perfect for laying out a mat for a painting. The brass knob compresses a small leather disk to lock the position of the sliding block of the gauge. A pic of all the parts of the gauge...
The underside of the gauge shows two holes for the pin. The forward one enables drawing circles down to about 1" in diameter the aft one can draw circles of aprox. 19" in diameter.
This shot shows the compass mode...
Like I mentioned earlier, I attempted to have the gauge fit my hand comfortably. Here are some images showing how I carved the sliding portion of the gauge...
This shot shows me holding the gauge. It does feel very comfortable holding the gauge...
BTW this gauge was made from some hard maple I had on hand but you can see the wood has some flaws. Worm holes? I don't know. They were filled with a white soft semi-powder like material... anyone have ideas of what it is? Also, any ideas on how to make it better would be appreciated.
Re: New Marking Gauge
Jim Ritter
Nice marking gauge. I have a bunch of small fancy wood this would be a great project for it. How is the pin held in place? Friction?
Robert Tutsky
Robert Tutsky
Yes, it is held in by friction. Right now the pin fits tight and need to use a plier to remove it. If it becomes loose what I most likely do is just dab a bit of shellac into the hole to snug the pin again. I don't see it used as a compass all that much.
Nice, very creative design
This bodes well for your making. As you get rolling again, making stuff, some pictures of your work will be much appreciated, too.
I like it!
John in NM
Very nice work! Thanks for the post :D
William Duffield
The damage is from powderpost beetles. The white powder is called frass. If you google powderpost beetle, you will get lots of good info from universities on life cycle and control.
Robert Tutsky
Thank You!
Question
Bill Tindall
You seem to have solved the thing I find annoying bout this kind of gauge, namely hot the slidy part "grabs" the shaft. Will you provide more detials on the leather "clutch"? How is it fastened in place?
Robert Tutsky
Re: Question
Robert Tutsky
It's simple really. I cut two small circles of leather that were pushed into the tapped hole where the knob is. Screwing the knob down, even lightly locks the gauge in place. The reason there is two of them is I mistakenly cut the knob shaft a little too short.
Very nice work
Robert Tutsky
Thanks
Hi Robert
That's a terrific well thought out design. I like the idea of converting it to scribe circles - never considered that before. Ideas!
Texchappy
Very attractive tool and looks comfortable and effective to use. Looking forward to see what you post up next!
Welcome back
That's a dandy gauge you've made there, Robert. The holes are powderpost beetle holes, and as long as you don't find any little piles of dust coming out of them, you can bet they are okay. I built a couple tables with maple like this, and I first blew out the holes with a soccer-ball needle on my air hose, then I filled them with Elmer's wood filler and stained everything to match. You can hardly see them.
Nice work. Thanks for posting.
Ellis Walentine, Host
