New WoodChat!
Disston saw history
Disston saw history
Disston saw history
Philip Duffy
Anyone have a reference for the Disston saws that includes variants of the production styles? I am currently working on restoring a very old and somewhat rusty D-8 that is actually 10tpi. Wondering if that is a mistake or a intended result. Thanks in advance. Philip
Re: Disston saw history
So far as I know, the model numbers did not refer to the teeth per inch.
Thats a good one !
Philip Duffy
Bill, That is a good point, one I had not considered. I do have 2 saws, both marked "8" on the blade,(not parenthesis), both the same length, identical handles but one is 1/2in less wide along the entire length of the blade and it has 10TPI. It can't be from sharpening as both saws have very little ware and tear.
William Duffield
What wear and tear would you expect to see from using and resharpening, and eventually retoothing, jointing and resetting the teeth? You get wear and tear from droping the saw from scaffolding, throwing it into the back of a pickup truck, leaving it out in the rain, letting an untrained 500# gorilla use it, etc., but not from using it as it was intended.
If the saw plate has 8 stamped on it, then it was originally manufactured with 8 TPI, not 10. Retoothing it to 10 tpi, of course would not have removed a half inch of the plate, but if it was retoothed once, it might have been retoothed more than once, not to mention resharpened many times.
Philip Duffy
Sorry Bill, think your assessment is way off on this one. The saw in question was clearly marked as 8 and has 10 tpi, with no evidence of wear, tear, truck throwing or any re-cutting of the teeth. Someone at the plant did make a mistake and the saw sold "as is". It does cut very nicely, once resharpened, etc.
Philip Duffy
Sorry, Bill, you are off base on this one. The saw shows no evidence of re-cutting of the teeth,etc. or any other abuse from trucks, etc. Incidentally, it cuts very nicely when I re-sharpened, etc.
William Duffield
Phillip, I didn't mean to imply that your saw had seen any misuse or abuse that would be evidenced as wear and tear. Maybe I made a mistake in assuming you are not the original owner of the saw, because most of my favorites are much older than I am. OTOH, a retoothing by an expert saw sharpener should leave no evidence other than a narrower plate and a mismatch between the tooth count stamped on the plate and the actual tooth count. I've had a few saws sharpened by the late Tom Law, and at the same time had two of them retoothed. Sometimes, it's easier to completely remove the existing teeth and start over than to try to correct a history of uneven sharpening. Tom's service was so reasonably priced that changing the tooth count, or changing from rip to crosscut or vice versa, to more closely fit my intended use for a nice old saw, was a very easily made decision. In any case, they all look and cut as if they were sharpened by the SNOS of Henry Disston himself.
