New WoodChat!
Shoulder/Veneer press screws--Thanks, LV
Bruce McCrory
I have been 'futsing' for several months trying to get suitable vises setup on my "desperation work bench"; or, "Roubo's Bane". The first effort--a wagon vise from a pipe clamp bound up. I can beat myself to a pulp, but Galooting just does not work for me.
The next is a tail vise I really don't want. I would prefer something on the order of a leg vise; something that will innocuously extend the working length of the bench--it is only 48-inches long. If I can find the receipt, it goes back to brand X.
This week I re-thought a front vise setup. Some folks are doing Moxon style clamps with acme threaded pipe and bedded nuts. That's going too far into galootism for me, especially at about $90 for the completed hardware (plus, tooling).
However, the Moxon style is exactly what will expand the usefulness of my bench.
So, today I went to Rocky to get two 9-inch veneer press screws. Sorry, that's overall length of 9-inches. The net screw opening is 6-inches, of which a jaw will grab more dimension. It's a pretty funky looking pile of steel, too. I left for the big City, just a few miles farther.
At WC, they had the very same thing for $1.50 more. They called it a 9-inch too. I bit my tongue and left the store with two ... And, my eyes on Harbor Freight just across the street.
And, I still have to fiddle to turn the stinkers into Moxon screws.
I got home ... and yup! Lee Valley, on-line, had what I needed in far better quality, and the full 6-inches of clear jaw opening--Their shoulder vise. No fiddling, either! They even provided the critical dimensions. I ordered the new blade for my Low Angle plane at the same time.
Re: Shoulder/Veneer press screws--Thanks, LV
James Watriss
Bruce, you need to post pix of your bench.
You need help.
We must give it to you.
And I need more wine...
William Duffield
Moxon didn't need Acme threaded steel rod and nuts to make his work. I've found that 3/4"-10 UNC threaded rod and nuts from the Home Depot work just fine, even though they are overkill compared to the original Moxon implementation in (probably) beech. Hardware will cost you only about $11. You'll have to make a pair of handwheels, which is easiest using a lathe, but I've seen several made without a lathe. I use the instructions provided by Benchcrafted as inspiration for mine.
Bruce McCrory
Hi, James, William. Thanks for the ideas.
I did do the HD and Lowes trips for fabricating screw vises, but as this thing will serve as a main front/face vise, I wanted operating to be speedier. I will go with HD threaded rod and nuts for one [end] leg vise. The veneer press screws will be returned when I get the shoulder vise screws from Lee Valley. After all my fussing around they ended up being only a couple dollars more than the veneer screws.
No pictures at this time, but will try and post some when weather cooperates.
The bench can be called "mobile", or will be, since it is only 48"w x 21"d at the base, with 48" x 16" deep table surface. Rear legs slope into the top. I plan to attach casters at one end so it can be jacked up at the other with a helper cart-dolly and moved.
My intent is to do the Moxon-style vise at about 42 to 48 inches jaw width along the front. It will be a fixed, permanent part of the bench. It's not really a Moxon vise, but that was the inspiration for mine.
Yes, I do want safer handles for the screws. I will study the Benchcrafted design more.
