How to Remove Epoxied Chisel Handles
Phil
Old socket chisel: handle has apparently been epoxied into the socket. I'd like to recover both the chisel and the handle: what is best way to remove handle from socket without destroying either of them?
Phil
Re: How to Remove Epoxied Chisel Handles
Richard Jones
Try putting the chisel into your freezer for a few hours. Wood and metal contract at different rates, sometimes they will pop apart with a bit of rapping persuasion.
R
Heat gun
Bob Hackett
Heat will cause the epoxy to soften and release. A heat gun offers more control than a torch or stove burner. If the steel turns color you`re using too much heat.
TomD
Epoxy has quite different abilities to resist heat. When removing golf clubs, I have had to heat them so hot, that they went off like Roman candles, at other times boiling water successfully broke the bond. You could try boiling the metal bit in water, and once it got hot enough, see if the handle will come off.
Sometimes handles can be removed by holding the blades and then hitting the side of the handle against a baulk of wood. Keep at it working around the handles. Ideally the baulk should be softer than the handle. This method can even remove chisels with a long tang, where a lot more has to happen than just breaking a bond. Epoxy does not always bond well to steel, unless it is well prepared. So you might get the bond to break, with just the impact on the block.
Brian from Monument
Thermal shock is a good idea.
Once you get the chisel free of the handle, epoxy cannot handle physical shock very well.
At least the stuff I use in glass bedding hunting/target rifles cannot handle physical shock.
Once separated, a punch can be used to break chunks of epoxy away.
A dremel with any cutter will grind it away also.
boiling?
more details
Bill Tindall
If the main body of the chisel is heated much beyond 350 F (depends on exactly what steel it is made from and how it was heat treated) the hardness of the chisel will be lessened. If you capture the blade in something that will be a heat sink, a metal vise for example, or wrap with wet towel, you can then heat the upper part of the chisel with heat gun or torch and the epoxy will yield quickly.
Be wary of heating the wood handle while heating the metal. If the moisture content of the wood handle is high, rapidly heating this wood will surely crack it from rapid loss of moisture and shrinkage.
Re: How to Remove SILICONED! Chisel Handles
Phil
Well sometimes you get lucky: turns out that clear silicone looks very similar to clear epoxy. I decided to use a hair dryer just for kicks to see it it did anything, and I discovered that you can remove handles that have been SILICONED in with no problem. If I ever do come across some epoxied handles, I feel well equipped to deal with them. Thanks for the suggestions.
are you shure?
Bill Tindall
Cured silicone is exceptionally heat resistant. One can make gaskets from it for a car's cooling system, or coatings and vessels that can be baked. The cladding on my oven thermometer cable is silicone and it handily survives 500F.
Yup
Phil
Yes, once I got the handles off, I was able to scrape the silicone off with very little effort. It was definitely not epoxy. Whatever it was, it was my good fortune that I am able to recover the original handles (these are EA Berg socket chisels by the way) and use these to turn some custom handles (when my son teaches me how to turn on his lathe). Or better yet, maybe I'll have him make the handles while I sit and watch (it will be like watching the New Yankee Workshop live).
