New WoodChat!
Neat vise design
Neat vise design
Neat vise design
I picked this vise up today at a yard sale:
Interesting design. It's clear the maker intended you to use the front edge of the bench as the rear jaw of the vise. I thought for a minute that this was a well-done later solution, as the rear "jaw" appears to be channel stock. However, there's a nut cast into the "channel," which I thus conclude is a casting, not a piece of steel stock, and probably original. 10" wide jaw, 9" opening.
All I can find on it as "Made in U.S.A." and, by the dog slot, "2433." No maker name.
Re: Neat vise design
I have a similar one...
John in NM
That uses the edge of the bench as the inner jaw. I haven't looked too closely at it though, a friend of mine gave it to me and I don't currently have plans to use it. I seem to remember it has a patent date on it, so it would probably have a manufacturer's name as well.
Re: I have a similar one...
Patrick Gibbons
You suck. That's a fantastic find. It looks great. I hope you put it to good use.
Re: That's Easy
William Duffield
Build a meta-bench (a.k.a. bench-on-bench) around it.
