New WoodChat!
Loose saw handle
Loose saw handle
Loose saw handle
JasonInOC
I am cleaning up a Disston D7 of newer vintage. The handle was a little loose (towards tooth / towards back rotation) before I removed it. What is the recommended method of tightening the handle? It seems I can
1. Grind down the screws so they don't bottom out
2. Put washers under the screws
3. Put a shim next to the blade
These are newer screw-posts, not split nuts.
Also, what were the handles generally made of? Any advice other than strip the rotten finish and BLO it?
Re: Loose saw handle
Blade
JasonInOC
Here is the blade after sanding with 220. The back side got naval jelly and a brown 3M pad, so it is cleaner. I didn't want to lose the etch on this side, though.
Re: Blade
Patrick Gibbons
Jason,
I find that naval jelly turns the steel a funky gray color. If you use mineral spirits as a cleaner with 320 grit sandpaper that will usually get rid of the rust and not really damage the plate. Others use wd40. If it has heavy rust you can first use a razor blade as a scraper. Your handle is made of beech. Unless your wood is warped, I think that just tightening the nuts down tight will take care of your problem. Without seeing the saw it's tough to say what else I might do. The side of the plate you showed looked nice. It will be a good user when you're done.
Ron in Sterling, CT
I agree with Jason. Try to tighten the nuts enough to keep the handle from moving before attempting any of the other methods you suggest.
I would remove the old handle finish with sandpaper, then give it a coat of BLO, let it sit for a couple of days to fully cure, then spray on a couple of coats of rattle can lacquer. Finally, wax the handle, and the blade. Should make a good user saw.
Ron
JasonInOC
I will try tightening the nuts, but I think they might be bottomed out on the screws.
I may have mis-typed, the blade in the picture is sanded 320 with mineral spirits.
Re: Loose saw handle *LINK*
Lars Parrington
Jason,
If you are going to strip and refinish the tote anyway, you might think about reshaping it. I like what Derek Cohen did to his miter saw handle here:
One reshaped handle coming up
