New WoodChat!
Bench Vise -- Metal not wood.
Gary Smyth
I've spent some time and been all over the web researching heavy duty American bench vises (mass 80 lbs or over) and I hardly ever see information relating to the diameter of the screw. It seems to me that the larger the jaw the larger the diameter of the screw ought to be. Also the thickness of the base plate. So, if I really want to honk down with a HD vise what is the essential data I need on a vise to make an intellegent decision?
Please, no Chinese or blacksmith data.
Re: Bench Vise -- Metal not wood.
James Watriss
Your logic is failing you, I'm afraid. A 1/2" screw in a scissor jack will hoist a car. Most bench vises have 1" or 1.25" diameter screws, and those will exert more force than 2 people will be able to apply. Chances are that the bolts holding it to the bench will fail first... Or the bench will tip. The rest of the casting will be made for robustness, but the screw will most likely be chosen for being of a commonly (affordably) available size and pitch, and not designed specifically for the vise.
Start with the assumption that most of the available vises will be overbuilt, and strength is not an issue. These things were built for abuse... Many include an anvil.
Agree
Yes, and
The nut is often fastened in some manner to the base plate, rather than being integrally cast, and sits inside the slide - (a) if you had a huge screw, I'd expect the weak spot to be the fastening of the nut, and (b) too large a screw would require too large a nut to fit in the slide.
I'd go for brand. Parker and Prentiss are excellent names. Wilton is a good name, too, but their vises seem to go awfully high. There are no doubt other honorable names.
An 80 pound vise is considered lightweight by a lot of vise fans. The Prentiss I dragged home from my father's garage, and which presently sits in storage awaiting a shop remodel project that I never seem to have time for, weighs somewhere north of 100 pounds (far enough north that I don't even like to move it around).
Re: Yes, and
Jim Ritter
Reed is another good name I've seen Athol once in a while. You searching for a used one I assume. If you are searching c'list be sure and search both "vise" and "vice". I found an amazing 80# woodworking vise under the wrong spelling. If I just looked under vise I never would have found it. Good luck keep us posted. Vises really are my vice.
Re: Yes, and
Patrick Gibbons
While researching vises for something else, my findings were that 1 1/8" was fairly standard for most metal vises. This applies to Oliver's and other American-made vises that I looked at. Emmerts and clones were also this size. I would be interested to see if you find some other size that was common.
Re: Yes, and
Patrick Gibbons
On second thought, I believe I'm wrong about Emmerts and clones. Also I looked at 20th century iron. 1 1/8" was quoted in Oliver ads I've seen and was speced for Morgan and Yost, if I remember correctly. It's a size that's definitely large enough to handle anything. I believe Oliver also used double threads on non-quick release vises.
Re: Yes, and
Jim Ritter
Ok, I'll measure the ones that I have tomorrow.
Re: Yes, and
Jim Ritter
I'm pretty sure my Emmerts pattern makers vise is 1" double thread.
