Re: problem with tearout
Wiley Horne--So. Calif.
Hi Eliot and all,
Congratulations on finishing the kanna! More on it below.....
But first, you indicated you have more than one plane. I suggest you get the blades on all of them sharpened to your best, then test them all, taking fine shavings from that same piece of maple. Do they all yield the same results? Which works best? Which gives the most trouble? Details are important here. This is an initial trouble-shooting step, to pin down where the problem is, and where it isn't.
Specific to the kanna. Is it a double-iron plane, or does it have only the main blade (the Japanese make them both ways, though you see more with double irons). What is the bedding angle? How is the sole prepared--where is it touching the work?
Check: is the blade cutting symmetrically across its width: put a narrow stick in a vise (or just hold it in your hand), set for a fine shaving (1 thou or less), and test the shaving thickness across the width of the blade. Don't need to measure--you just want to know is the cut symmetrical across the blade width. This will tell you whether the blade is installed somewhat askew--if it is, you'll likely get tearout no matter what else is happening. If it turns out the blade is askew, and there is not enough lateral room to adjust, you'll need to provide slightly more lateral room, using either a side float or a 1/8" chisel, taking care not to alter the top or floor of the blade channel.
You can also test whether the kanna has full bedding support down near the cutting edge. And again, is this a single blade or double-iron plane? Pencil the blade bottom and insert it to depth, and look where the pencil marks are on the bed--do you have contact at the lower end? If this is a difficult test to run, or to see the results of, take a Post-It note (they are about 3.5 thousandths thick) and stick loosely to the bedding of the plane, and particularly at lower end. Re-insert blade to find out: will the blade still extend to cutting depth using the same hammer-tap force as before? If it does, recheck the blade for skew and see how it cuts now. If you have to tap harder, restrict the post-it to lower end only (last 1/2" of bedding contact, say) and recheck. If it's still taking a heavier hammer-tap to get to cutting depth, then you know you're about right without the paper shim.
Finally, on the kanna, regardless of tearout, are you able to consistently get a full width shaving off a flat board? Or is it erratic--cutting, then not cutting, sometimes digging into the board, or cutting one-side only? If so, this is an indication of a high spot on the sole, typically just to the rear of the blade, though it could also be in front of blade. Let us know if there is a problem in this regard, and we can take the next step.
Main thing to check first, though, is to test additional planes on the same pieceof maple
Wiley
