New WoodChat!
Question about wooden moulding planes
Rick Snyder
Hello,
I have several wooden moulding planes and with some of them I'm still getting shavings stuck between the blade and the plane wall. The blade is sharp and projects a pinch above the plane profile. What am I doing wrong? The plane in question, has a multiple or "ogee" type profile( if I'm saying that correctly).
Thanks Rick
Re: Question about wooden moulding planes
Jim Crammond
Rick,
Check to see if you can detect what is stopping the shaving from exiting the mouth. In my experience, the biggest culprit is the end of the wedge has been broken off or it's flat and the shaving is hitting it or it is getting behind the wedge and jamming. It can be frustrating finding the cause but be patient and don't give in to the thought that you just need to open the mouth. I've seen a number of planes where the previous owner removed about 1/8" of material to open the mouth and the plane still jammed.
Good luck,
Jim
Re: THANKS Jim for your reply!
