How to make stain-answer to question below
Bill Tindall
I prefer a mineral pigment stain. Iron oxide, for example, will remain the same color for light years and more. Synthetic dyes and pigments won't. The reason I use a stain is to keep wood roughly the same color over time, especially walnut which will bleach blond over time. To that end I stain all walnut, mahogany and cherry and some oak.
There was a time when all stains were mineral pigments. Now they are more often synthetic pigments and dyes and companies seem bent on reformulating every few years which drives one nuts trying to maintain a finishing schedule. So I concluded "screw it" and started making my own stains and fillers.
There are two routes to a pigment stain. One case uses "Neutral" General Finishes stain/conditioner(as recommended by the General Finishes chief formulator). The other case uses linseed oil as the liquid portion.
I have used various sources of mineral pigment but what I have found best is Moser's Japan Color available from Woodworkers Supply. It can simply be stirred into the General Finishes product. It must be worked into linseed oil. A lot of stirring will accomplish the task or a lesser amount of grinding it together with mortar and pestle or equivalent. About 10% pigment by weight in the liquid is a good starting place for formulation.
