Earthquake in Maine!
Jack Guzman from Maine
I just thought my water heater blew up until stepson called up from two states away and said he felt it too. About 20 miles from here. 4.5---Jack
Re: Earthquake in Maine!
eliot d
Hope you're all right!
I remember one...
John in NM
I think it was in 1979, I was living in Ashland, Maine.
Earthquakes everywhere
That's a big one for your part of the country (it's considered enough to talk about but not enough to be freaky here; but we get a few more than you do). They do occur everywhere, but they're mostly so small as to be unnoticeable, unless you live on or near the meeting point of crustal plates.
I hope you and yours, and everyone in your area, are OK. The big problem with quakes in non-quake regions is that houses are often not constructed for them, and fall down.
earthquake proof?
Our water heaters might fall over but most Maine houses are built with snow loads in mind so they are pretty rugged. ---Awed but undamaged---Jack
Re: earthquake proof?
Yes, you probably have good lateral bracing, to hold the house up when it's covered with snow. How well are houses bolted down there? One of the biggest failure points in serious earthquakes comes from houses being jolted off foundations.
In new construction, code requires a pressure treated sill plate bolted to the foundation. I always considered it overkill but at least a tornado won't lift the house and drop it in oz.---Jack
Like many codes...
John in NM
That one is a "one size fits most" and not really suited to the local conditions you have up there. Similar one out here concerns venting crawl spaces - soil is dry as the inspector's eye most of the time, but we still have the same venting and vapor barrier standards as they use in coastal Virginia
I also remember the dregs of a hurricane coming through when I lived in Orono, though it was a "tropical" storm by the time it reached us that far inland. Don't remember any old farm houses getting damaged though.
