Seemingly Un-busy
Bruce McCrory
To clarify, I was busy, but doesn't seem so, in retrospect. Two things:
First, after 18 years I finally managed to attach the cold air intake grill onto the wall. It's an indoor furnace, there was no framing wrapping the metal ducting, and I don't care if it is illegal now. Or, not. It was one of those most frustrating jobs with absolutely no visible satisfaction for a "job well done." I even made a passable match to the original drywall texture.
Second, I finished my Gramercy Tools dovetail saw kit. (See photo, if it loads.)
The kit includes toothed and sharpened blade, brass back, and two saw bolts/screws. I provided the sweat and blood, and a scrap of maple firewood Rockler felt was worth 99-cents.
I got the wood to experiment with figured and crappy grain. But it was the right thickness and if I stretched it, could cut a handle. Then I flipped the wood over and discovered I could almost mirror the handle. So, knowing my skills, I cut a handle blank leaving room for a second. The one in the photo is the second handle. Of course.
The wood grain follows the handle profile. Fiddle-back figure radiates from a knot, or bark flaws, that defined the inner space of the handle. My poor, old, 12-inch band saw barely cut the outline. I used a cheap multi-grain rasp to shape everything. The last insult was drilling for the bolts with a horrible Ryobi bench-top drill press. I had to laugh, because the guide holes in the blade (as delivered) were too small for the bolts. There is only a 64th difference between bit (drilled) and bolt diameters, now.
Over a period of a week I rubbed in linseed oil and let the wood sit for another week.
Another experiment was trying french polishing.
The first coat of shellac was a disaster. But it showed that the wood was far from completely sanded. I removed every scratch I could find, then continued sanding through 320, 400, 600 grits and a soft paper that I think was finer than emery.
I bought garnet/brown flake shellac to create a warm, glowing, maple finish; started polishing sessions.
French polishing, as a name, is about 200 years old. Using tiny rag-dolls from old tee-shirts, or wife bought male insults, called muneca; a tiny bit of shellac flakes, a pint of alcohol, a few drops of olive oil; and a thousand hours of rubbing you can build up an incredibly thin and beautifully polished film. Every scratch and flaw will amplify during polishing sessions. Even unknown failures evolve during french polishing.
My rag-doll might have been too dry, but an impatient attempt to stiff or pull-over the finish--and subsequent repair--proved material actually was being laid down.
Conclusion:
The take-away from all this ... minutiae is:
A. French polish is not for impatient woodworkers.
B. I don't need a router table to put Pedder's (Two Lawyers) machine work to shame. $100, and two weeks will easily do it--with wood from my kindling pile.
C. Buy a can of Deft (lacquer), snort MEK, and spend the extra $40, or so, on a finished dovetail saw.
