This week's accomplishment (long, pics)
Today, I put up the last piece of siding on our current remodel. This remodel has, as with most of our work on the house, involved the noise of many electrons working their little hearts out to cut/shape/etc. the wood and related parts. But, on our 115-120 year old house, there's always room for handwork. We wound up replacing all of the exterior wall framing except four corner posts (two exterior corners and two posts next to the adjacent rooms). And the city made us install shear plywood on the pony wall*. The new walls are straight and plumb; the old walls weren't.
The (existing) frieze board** on one wall wound up with a gap to the framing that ranged from 3/4" to 1/4" over five and a half feet. Plus, of course, it isn't level, while the new siding is installed level. Since the 5/8" thick siding has to run up behind the frieze board for proper water shedding, this made for a challenge, and an opportunity for some hand tool work.
Here's the problem (it's worse than it appears in this picture):
So it could run up behind the frieze board, the last piece of siding got a rabbet that ranged from nothing to 3/8" in depth, and 1-1/8" to 3/4" in width. I'm terrible at in-process shots, but my approach, in essence, was to clamp a batten - actually, an aluminum guide normally used to guide a circular saw or 'lectric router - for the width of the rabbet; make some marks on the board to designate starting point and terminal depth (I added a midpoint depth, to make me feel better); and go to town with the Stanley 78 for the main work and Lee Valley shoulder plane to clean it up.
You can see how dramatically the rabbet varies in width and depth:
After priming and carefully tapping it in place (I had no desire to break that 1/4" thick wood at the deep point of the rabbet), I have a resolution for that wall that meets the 30-30 test***.
I was wondering, while I was making it, how I'd have done this with power tools, and finally decided I'd have had to make a jig to hold the board on edge, angled in two dimensions, to run over the table saw; and another with the board flat, and angled in two dimensions. My head spins.
*For those not familiar with framing terminology, this is the wall between the foundation and the floor level of the first (ground, for our English and English-colony members) floor.
**We could have pulled the frieze board and soffit and reworked them; but that would have led to reworking the rafter tails, which would have led who knows where...you have to pick a point at which to stop, or you might as well just tear the house down and start over.
***How does it look from 30 feet away if you drive past at 30 mph?
