New WoodChat!
getting kanna pin right
eliot d
I'm about to put in the pin. But I have this feeling that no matter how careful I am, the pin won't be absolutely parallel to the sub iron. For example, I just don't trust that I can use the drill press, start on one side and have it come out exactly right on the other side. I suppose I could mark both sides and drill first on one side then on the other. But I still have my doubts. Any thoughts - other than get everything square and work carefully.
Re: getting kanna pin right
Possible help
Wiley Horne--So. Calif.
Hi Eliot,
Here's a thread that gets into this issue. Scroll about halfway down the page, and the poster 'Sheets' provides some text and drawings, following the method of Odate. I think you have to register at the site to see the drawings, though. I couldn't access them straightaway:
http://www.woodworkforums.com/f111/someone-have-dai-kanna-making-tutorial-114998/
Wiley
eliot d
Well, I went ahead and did it the best I could. Following the books is o.k. but it's just a starting point. What I did was put the blade and sub blade in place and carefully estimate where the pin hole should go. Sure enough, when I put in the pin, it was too close:the sub blade wouldn't go down far enough. The pin was the smooth part of a long bolt, which is a little over 1/4 inch in diameter. Since that's a bit large, I was still in business in that I put the pin in the lathe and cut it back to about 3/16 in diameter. That made all the difference, so now the sub blade seats just right. The kanna is now just about finished except for some scalloping of the sole. It cuts beautifully even with no scalloping. I know how to post pictures now, so I'll follow up later with some pics.
TomD
Absolute parallelism may not be the end of the world. The blades are sometimes domed, so they contact at one point, then bear on the forward edge and the two rear points. All of these are adjustable.
That said, a drill press should be fine. For it to work the sole and the resting side need to be square, or shimmed square, or clamped square, etc...
eliot d
Thanks, Tom. But it's really working great now. Good thing I have a lathe, though. It was too tight before I reduced the diameter.
I wanted to post some pictures now that ( I think) I know how to reduce the size , etc. My problem now is that I can't find the camera to computer hookup wire, and my wife , who knows where it is (again, I think) is away. Oh well. I'll get to it eventually.
