New WoodChat!
Drying apple -- the wood, not the fruit
Bruce, a MN Galoot
A friend gave me four wedges of an apple tree trunk, up to 6" thick and a foot long. It was cut a couple weeks ago. Is there anything I need to do, other than cross my fingers, to properly dry this notoriously check-prone wood? Will painting the end grain help? Cut into slabs?
Bear in mind that this is now fall in MN and humidity is pretty much a thing of the past, IOW, bone-dry.
Re: Drying apple -- the wood, not the fruit
Bill Tindall
A typical wood dries 10 times faster out the ends than through the sides. While I consider sealing ends a waste of time on lumber it could provide significant benefit in this case of very short lengths, providing the ends have not started to check. The limited air movement in an unheated indoor space could be helpful in slowing the drying rate while the cold will inhibit mold propagation.
But then what will apple do that maple won't? It may not be worth the effort to fiddle with it too much. Personally I have given up trying to dry fruit woods, though I have never tried to dry apple. Peach and plum are difficult.
Bruce, a MN Galoot
Thanks, Bill
The only thing that apple will do that maple won't is to look traditional on saw handles. I have the ends painted.
david weaver
keep your eyes on the ends and the sides for checks. If you don't have tons of the stuff, keep a bottle of CA glue around and as soon as a check starts, dribble CA glue in it.
Its behavior is worse drying than anything else that's ever dried from wet on my racks. I had it for the same reason you do, nothing else is comparable for saw handles when air dried good clear apple is available.
If all else fails.....
Bill Tindall
it works great in the smoker . Can you tell apple from birch in a used handle? They look about the same to my untrained eye.
I gave some plum to a turner. Lovely maroonish color wood. Turners are used to drying green stuff and can dry anything (except plum). After making several turnings from the plum and having all of them crack he concluded that plum could not be dried. I kept a piece at most 2 1/2" wide. The difference in radial vs tangential shrinkage was so huge that this tiny piece cupped into a trough.
craigd
craigd
Here is what I like and dislike about apple:
It has gorgeous (the color is really washed out in the photo) and is easy to work but is a major pain to dry. Paint doesn't seem to do diddly to stop checking (more like earthquakes), this year I put out of date shellac on riven white oak and that has worked well, it might work on apple.
Jack Guzman from Maine
If the piece I get is in the round I cut it to remove the pith but otherwise I set it aside and let it do it's thing. After it dries I sort through for the unchecked parts. Not very efficient but there's lots of apple around here and it's usually free.---Jack
Thanks, guys, and a follow-up
Bruce, a MN Galoot
Do you recommend slabbing out these pieces or leave them in quarters as they are now? And does the general inch-per-year rule apply?
Bart Goldberg
In my smoker - cooking Pork Shoulder:)
If all else fails, that's the plan
Do I need to explain again how useless....
Bill Tindall
.....the year per inch myth is?
yeah but..
..the skinnier you cut it the quicker it dries. If I get a piece that looks like it has a good saw handle in it I cut it into a slab big enough only to allow for warping. Apple does that when it dries. ---Jack
