Fray questions
Edward in Vancouver
Picked up a Fray #2 brace this last weekend. For 3 bucks, I can't complain, but there are some "Issues" I need to address.
1) Split chuck. Just how far does the split go? The one on my brace goes all the way to the first bend. Don't know how much more it will travel. Is there any way of stopping the split? Any way of correcting it?
2) Pad. A bit of slop in there, not a lot, but a bit. Don't know how the thing is attached to the shaft, don't see any screws, I see 2 oiling ports, but no screws. I also see a lot of gunk that probably is glue right where the pad meets the metal housing. Blond gunk, so if I'm lucky and it passes the "dog test", and it is hide glue and I remove it, just how do I remove the pad? Pad is cocobolo, actually in nice shape--with the ubiquitous white paint splatters, which I intend to remove, but that's about it.
Wrist pad has lost it's pewter rings a looong time ago. Brass wire on both grooves on this one, and kind crudely done too. P. O. even made a hole in one of the wood pieces to house the knot of the wire so it's below the surface. Can't blame him I guess, a nice wire knot like that rotating around in your palm would leave a scratch. Both wood pieces are intact and perform well, have no intentions of doing with this part.
Screw for the chuck is in good shape--under black paint... matter of fact the chuck was painted too. I think I see remnents of nickel plating, but I have no intention of shining it up, just removing the black paint.
