Re: Why didn't I think of this years ago?
TomD
If you are talking about grinding straight bevels as on chisels and plane blades of the simple type, it is really easy. The pinch does not guarantee results, but it is an anchor, or reference, and helps. Depends whether we are talking tool making, where one starts from a blank, or grinding a formed bevel. I assume the latter. In which case the basic skill required it to learn to float the tool on the wheel. This is a basic part of all power grinding, for me. It involves with the wheel spinning, delicately positioning the bevel so it matches the wheel, or if the bevel is flat, say, and the wheel convex, getting it spinning in the correct relationship on the wheel.
The floating is having contact, where probably some very small amount of grinding is occurring, the wheel is spinning, the correct relationship between tool and grinder is being observed (or one thinks it is). The reason this is important, is because to go from floating to heavy grinding requires little more than pressure. If you simply whack the tool onto the wheel, you have less reference than if you find the groove through floating first. I'd say there probably aren't sparks when you are floating, or not many. You could heat the tool a little, so probably best to get on with it.
Once you apply the pressure, get the blade moving back and forth across the face of the wheel. This should be done with the legs. Keep the arms tucked and supported, they clamp the blade in reference to the body.
After you have ground a little check to see if you are making the right marks. If not, make an adjustment, float it traverse it, check it.
Grinding is basically just turning in reverse. You use the spinning thing to shape the tool. Making a straight cylinder on a lathe, is not one of the harder things to do. Almost anyone can do it. Grinding a straight bevel is what you would get if it turned out you weren't cutting a straight cylinder but rather you were all along sharpening the straight bevel on the wheel.
