cutting an old saw blade
eliot d
I read here once that people sometimes cut up an old saw to make a scraper blade. But how would you cut a saw blade without special equipment? I have the feeling that the metal is kind of tough.
eliot d
Re: cutting an old saw blade
bridger
if you have an angle grinder go buy a thin slitting disk for it. clamp a board to the saw blade at the cut line and use it as a fence. you don't have to go all the way through. make a good deep score and it will snap.
otherwise, you can sacrifice a pair of tin snips to the cut. it will cut it, but it will also trash the snips.
Neal in San Jose
Use a Dremel (or equivalent) with a cut-off wheel to establish a groove, then snap it off. Of course, the pedal powered Dremels are a little hard to find. I've heard of using a three cornered file to worry a groove, but I've never tried it.
steve mackay
I use the Dremel with cutoff wheel. Scribe your line and just come close. Then "slide" it over the bench sander belt to get a straight edge down to your line. Just don't let it sit there too long or it'll "burn" (turn blue). My first time I was over-think'n it. Don't. It's easy. The average human can do it.
craigd
I bought a 8" shear, works great, even for shaped scrapers.
Aircraft snips also work well but can twist the metal a bit.
I personally don't like using a cut off wheel (I do it a lot for cutting plane blades) because of the extensive burning.
I've also scribed a [straight] line, using a carbide scriber, and snapped the metal, which works well once you get the hang of it.
First you scribe a line...
Bob Hackett
Then you clamp the saw blade in your steel jawed vise with the line you scribed just visible above the jaws. Take a freshly sharpened cold chisel held at a shallow angle to the blade and use a mallet to power the chisel along the cut line.
No burning, no loss of temper (either the saw`s our yours) and if you cause a few defugalties starting out you can usually tap them out with the nearest hammer while learning a bit about saw doctoring if you become too heavy handed in your hammer work.
You can also punch holes in saw blades using this same cold punch technique. I use a pin punch of the correct diameter and support the metal on a block of end grain softwood. If the edge of the punch is sharp and clean you can get a a sharp clean hole with one good whack. Be sure to move the metal to a new, fresh area with each new hole.
Stephen Shepherd
What Craig said, use snips, works remarkably well. I have a pair of 19th century 'tin snips' that make short work [but it is work] of cutting up saw blades.
Stephen
TomD
I would not want that. I like a thinner scrapper; they do not cost much; they last a long time; and there is litle guarantee the blade is uniformly hardened, since there would seem to be little reason to harden anything other than the teeth. I have an Inca saw, and it has a 20mm arbour. I bore 5/8" arbours out on the lathe. They do not seem that hard. Antique stuff probably shouldn't suffer this fate, and it was even less likely to be hardened uniformly. Though obviously is working for some.
