New WoodChat!
200+ woodworking book reviews
OT: Epoxy vs. Titebond II in exterior application
Well, somewhat off topic...I know there'll be lots of hand tool use on this one.
I'm going to be cutting a tapered hole in our 9" wide horizontal wood siding to add some blocking behind a tiled wall (bathroom shower) to accommodate a grab rail. I'll fill the hole with a big dutchman (patch), tapered to match the hole but slightly larger; then sand off the excess and repaint.
I use Titebond II a lot, and am pretty happy with it; but I'm not 100% sure that I'll get perfect gaps on the joints, so am weighing epoxy vs. Titebond. Has anyone ever painted a narrow epoxy glueline successfully? I plan to ask the manufacturer, too; but thought I'd inquire about field experience from this group and its wide-ranging experience.
Re: OT: Epoxy vs. Titebond II in exterior application
William Duffield
If you have structural gaps that need to be filled, there's no better solution than epoxy, with a filler (either colloidal silica or wood fibers). If you are worried about painting over the epoxy, prime it with Zinsser B.I.N.
Jesper, Denmark
Jesper, Denmark
I would go for the epoxy with a high density filler to add strength. Colloidal silica is just to control viscosity.
Painting over is no problem, but wipe the surface with a wet rag after the epoxy has dried to remove any amine blush from the epoxy. If you have sanded down below the original cured epoxy surface, this is not necessary.
Note that epoxy is UV sensitive, so painting over it is necessary in exterior applications.
TomD
Epoxy for sure.
"I would go for the epoxy with a high density filler to add strength. Colloidal silica is just to control viscosity."
First epoxy by itself, of the quality type, like WEST is all you need. Fillers modify the epoxy in accordance with the rule of mixtures, and may be beneficial. Colloidal silica does control vis. so that if you mixed wood flour into the epoxy to thicken it, then applied the mix, you might see the epoxy run out from the mix leaving the wood flour behing. CS controls that kind of thing. But it is also rock, so in accordance with the rule of mixtures if you mix enough of it in, it will start to modify the epoxy to be more like rock. Basically what is going on with cultured marble. CS and epoxy is an excellent glue. But beyond a certain ration it can be brittle, but not something I would worry about here. Also, CS yields the lowest volume of usable glue when one is making a mix (bogg for short), so I always use the least I can and use say a hollow sphere to keep weight down and maximize yield.
Stuff like 5 minute epoxy already comes thickened, so fillers or CS are probably not a good idea. Nor is using 5 minute.
Painting, I just sand, apply Behr exterior primer then paint. Not the most durable bond, but good enough for most stuff. I use this on boats, so one can be walking on it. Sometimes an abrasion will remove paint right down to the epoxy with depressing ease, but then it is like sunblock, easy to re-apply.
Gougeons have a good free mag you can get, and some of the issues are online. Epoxyworks.com. Go there look at "Epoxyworks articles arranged by subject", sellect the first catagory, and crt + F for "paint". Good scientific article on paint primers. Bill, you will be in deep clover!
"Note that epoxy is UV sensitive, so painting over it is necessary in exterior applications."
You can also add a pigment to the epoxy. However, this is not a coating application and penetration into a joint is not to critical. If one uses epoxy as a coating, it is quickly damaged by UV.
I like West Six 10 *LINK*
This is a very thick epoxy and very convenient for the application you describe....
West System Six 10 Epoxy
