Flip-Stop (for Power Tools)
William Duffield
Here’s another tip on a very useful and simple appliance that I picked up from Steve Latta’s SAPFM presentation of two weeks ago. It is a flip-stop, for cross cutting stock to length on a table saw.
The stop clamps to your table saw miter fence or sliding cutoff table (A.K.A. Dutchman). It also works on your chop saw or radial arm saw. You flip it up and pass the stock underneath it to crosscut the first end square. Then, you turn the stock around, flip the stop down, push the stock against it and crosscut the other end precisely to length.
I used to use the Kreg KMS7801 Swing Stop for this application, but it doesn’t operate as smoothly, takes up a lot of storage space, gets in the way when you are using it, it is expensive, it requires you to mount Kreg t-track to the top of your fence, and a much wider fence is required.
http://www.factoryauthorizedoutlet.com/images-400/KMS7801.jpg
The shop made versions are so easy to build and work so much better, there is no reason to ever get the Kreg stops. I shouldn’t be telling you this, because I will make it that much more difficult when I try to sell my pair.
I built my stops from tulip poplar, and glued a tab of 1/8” Baltic Birch ply to the top. Something harder than poplar, like rock maple or jarrah, would probably wear longer.
You can’t use just any old cheap hardware store hinge, because the barrel and pin are too sloppy, which throws off your precision. Of course, Brusso hinges would be the epitome, but you don’t have to spend that much to get a tight hinge. I spent about $20 for good brass hinges at Woodcraft to build two flip-stops.
The other critical parameter is to make sure the end faces are perpendicular to the tab on the top, that squares the flip stop to the top of the fence. I found out it doesn’t really matter if the hinge is set square, except for aesthetics, because the stop is not used when it is flipped up. When I made mine, I mortised the hinges and used a VIX bit to drill the holes, and still only got one of the two flip stops square.
I’ve added some enhancements beyond Steve’s design. By drilling a half inch diameter hole in the top of the fixed block, I can attach it to the fence with a Festool 489570 Screw Clamp. (Be careful not to drill into the hinge screws.) These clamps make it a little easier to precisely adjust the flip stop, they work a little quicker, and I have a few of them around the shop for other applications where they have some significant advantages over typical F-clamps. They and the mortised hinges don’t get in the way of the flip-stop rotating all the way up like an F-clamp and flush mounted hinges do. Steve Latta typically uses a 3” high auxiliary fence, so his flip stop isn’t high enough to clear 8/4 stock and still give purchase to the F-clamp. See second photo, above.
I’m also considering adding a small rare earth magnet, to hold the stop in the up position. It might come in handy if I’m cutting lots of pieces of stock at the same time.
I built two stops, one to fit my 3-1/2” high TS miter fence, and another to fit my 4-1/4” high router table and drill press table fences. You need to allow about 1/8” clearance at the bottom, and also provide some relief to allow the fence to rotate without running into the table. Too much clearance at the bottom, and thin stock will just slide underneath the stop.
The router and DP table fences have Incra T-track mounted in their bottom faces, and I use the Festool clamps to clamp them to the tables. The Festool clamps do not fit Kreg mini-T-track. My drill press table top has only 3/4” overhang, which is not enough. My router table top has a 2-1/4” overhang. Even more would be better.
Construction tips. These might be helpful if you are going to make more than one flip-stop: I laid out all my hinge mortises on one edge of a straight board, about 3” wide, routed the mortises, and then crosscut the board into blocks. Next, I screwed the hinges to a pair of blocks. I squared up the sides of the stops, trimmed them to height, glued on the plywood tabs, drilled the clamp holes, and finally shaped the bottom edge for clearance.
