Second carving lesson
Rononkokomo
This is my second lesson. I think I am ready to try a little in my furniture projects. I am going to start with some wild roses in an apron of a small table in cherry. I will let you know how it goes.
Ron
Rononkokomo
Ron
Here is the rose..
Rononkokomo
It was my first lesson. I found the tutorial on line. Very easy to follow.
Ron
Re: Here is the rose..
Wiley Horne--So. Calif.
Nice job, Ron! I can visualize most of that. But you've got vertical cuts to define the thing in the center (pistil, I think), and horizontal cuts into the pistil defining the petals. Whenever I try to do intersecting stab cuts like that, I end up with unwanted gouge cuts at the intersection, where I went just a little too far. Those unwanted stab wounds then have to be filed or scraped out, because even if very, very shallow, they light up like crazy when the finish hits them. And look very ugly. Even if they're only 1/100" or so deep, they can be tough to get out without leaving an excavation, because of where they are.
How did you avoid leaving evidence of stab cuts at the base of the pistil?
Thanks,
Wiley
Knife
rononkokomo
I put knife horizontal and made careful rocking cuts
Patrick Gibbons
I did this project many years ago and don't remember it turning out nearly as we'll as yours has. You should be proud of your results.
