small butt hinges
les winter
I'm going to build some small jewelry-type boxes. 3/8" walls, around 7.75x12x5" tall. I'd like to buy some decent brass butt hinges. The ones I have purchased from LV are brass-plated steel. The taper of the holes doesn't match the available #2 brass screws; the screw heads are proud of the hinges. I suppose I could get the appropriate taper reamer and grind the holes at a better angle. Or find a source of more narrow-taper screws. Seems to me, I should be able to buy hinges and screws from one source that work together.
If anyone has a source of reasonably-priced brass-plated hinges and screws which match, or a better idea, I'd appreciate hearing about it.
thanks
Les
