New WoodChat!
Lee Valley Large Spokeshave Kit - Blank Size?
Scott in Douglassville
Hi, all -
I'm pondering on making the LV large spokeshave kit. I have a beautiful chunk of curly claro walnut that I'd like to use, but the piece is 10-3/8", while the kit spec's 11". Now, I never hold a spokeshave by the ends of the arms, so I think I'd be able to get away with each side being 5/16" short. Whatchall think? Functional? Wonky lookin'?
Scott
Re: Lee Valley Large Spokeshave Kit - Blank Size?
Jack Guzman from Maine
I'm thinking you'll be the only one who ever notices. The big question is,will it bother you? You could always add a brass tip to each end to pretty it up.---Jack
What Jack said, with a caveat
Bruce, a MN Galoot
I can't remember if I made the large or some other size LV kit, but it can be a bit tricky to get the angles just right. My advice would be to make your first attempt at something less valuable than that claro walnut. After you get it right, it works really well. Mine took a bit of fiddling, but I'd be willing to bet that was my problem, not the kit's.
Re: Excellent adivce
It is good advice. I made the small kit a few years ago, so I feel confident (maybe unjustified).
TomD
Ebony caps, if the other wood is as fancy. And no, you probably don`t need a dry run, though it is excellent advice in many cases.
Do you find it useful?
Bill Tindall
I made a small and large and have never found it to be useful. the blade is too flexible. Might be fine for softer woods. I bought the LeeValley set and find them excellent and use them regularly.
No, I'd say your confidence is justified!
Bruce, a MN Galoot
Very, very nice!
Re: Do you find it useful?
So far, yes. I haven't run into any iron flex yet at all, though I've only done fine work with the small. I'm hoping to do more hogging off work with the large; I'll have to see how it goes.
Re: No, I'd say your confidence is justified!
Thanks Bruce!
seat carving
The large spokeshave is handy when carving windsor chair seat blanks.---Jack
Re: seat carving
That's exactly what I want it for. Good to hear.
Re: Excellent adivce *LINK*
Paul M.
I prefer to make spokeshaves that have the handles toward the bottom of the spokeshave. I know the standard has these handles flat on the top so they are even with the top of the shave like you show in the picture. But this puts the handles up above the blade and cause the shave to want to rotate.
It seems much more ergonomic to lower the handles so that the blade is between your hands. Most of the time, you do not need clearance for your fingers in operating a spokeshave because you are working from a horse or a vice and your hands are in free air.
Here's an example in the link below, from the guy who taught me how to build these. This has a flat handle on the bottom, and is carved on the top so that you can get a good low grip.
Russ' spokeshaves
