New WoodChat!
Laying out drawer dovetails
Bill Tindall
I used to find this a tedious task because I don’t do it very often. I now employ crutches and training wheels to get to the same point, fairly quickly. A shop dovetailing drawers regularly would be able to lay out dovetails quickly by eye and it would look fine.
Pic 1
Picture 1 shows how I arrange the dovetails. The dovetails at the front of the drawer, which will be seen occasionally, are finer and closer spaced for strength. Those in the back where they are never seen are coarser and more widely spaced because they aren’t stressed when operating the drawer full of whatever.
The drawer front is laid out with a half pin top and bottom. The groove for the drawer bottom must lie within a tail so that the groove is not seen from the drawer side. This requirement results in a small half pin. Care must be taken to not split it out when assembling the drawer. I make sure this pin is not tight to ensure it does not split out. It might be better to use a half tail on the bottom but I don’t like the way that looks.
The drawer back is laid out with a half tail on top. I think a half tail supports the drawer when opening it better than having a half pin up here. The bottom is a half pin which ends at the top of the drawer groove so the drawer bottom can be slid in from behind.
Pic 2
Step 1 is to label the drawer parts. The sides are bradded together and together sized to just fit the height of the drawer and be ½” short of the depth of the case. When measuring for the length of the drawer bear in mind that the case may have a rabbit in the back for the back of the case. I shall not let that mistake happen again......I hope. Both sides will therefore be marked and sawed together, saving time. The grain is orientated to anticipate planing the sides of the assembled drawer.
Pic 3
Step two is to scribe exactly the drawer side thickness around four sides of the front and both faces of the back. I like this style of marking gauge because it is easy to adjust.
Pic 4
Step three is to mark the position of the drawer bottom groove. One must know where this will be so that the half pins front and back can be positioned correctly.
Pic 5
Step four The half pin for the drawer bottom-back is marked positioning it at the top of the drawer bottom groove. The top pin is arbitrarily located to look ok and not leave a delicate half tail.
A word about the dovetail template. The position of the dovetails does not have to be precise to look good. But if the size of the dovetails differs it can be seen across the room. This handy template makes making the same sized dovetails trivial, and quick. Note, it is adjustable for any sized dovetail (actually it is the pin that is marked). I am surprised this template is not sold by places like Blue Spruce, etc. It is easy to make.
Pic 6
Step 5 A divider makes spacing the pins trivial. It is set some arbitrary amount and then “walked” between the top and bottom pins. The space between the points is empirically adjusted until a point ends near the pin as it is walked between the pin locations. When it is about perfect a pin prick is made as it is walked and these pricks will be the centers of the pins. While this operation sounds tedious one can get the spacing near perfect in less than half a minute.
Pic 7
The template is centered by eye on the pin pricks and the pins marked. (the pin pricks are highlighted with a pencil mark in the picture) This process is repeated for the front of the drawer side, that part that engages the drawer front.
The result is perfectly uniformed sized dovetail pins attractively spaced on the drawer side. The next step is to saw. Because both sides of the drawer are bradded together at this point both sides are simultaneously sawed. I remove most of the waste with a band saw, nibbling it away almost to the base line and then paring at the base line with a chisel to complete the drawer.
Re: Laying out drawer dovetails
Bob
Bob
Thanks Bill nice write up.
TomD
It is not true that dovetails at the back of drawers receive no load. I have often seen this joint break. Silver drawers, the cutlery moves back and bangs the back of a drawer. On a lot of other drawers the bottom is attached to the back piece and whatever weight is in the drawer can slide back against the back.
Another thing I wonder about is that if a drawer will have a plywood bottom, which is certainly a quality panel choice if not a solid wood one, then I think there is a lot to be said for encircling it on all four sides. Worst case, if something goes wrong it is easy to remove the rear piece, and carry on from there. On wide drawers, or really long narrow ones, a ply bottom with the grain aligned to the narrow dimension is a very strong design.
Jack Guzman from Maine
Template
Bill,could you show a better picture of your template? Thanks for the informative post.---Jack
William Duffield
I don't see any significant difference in the information conveyed in your Pic 5 and Pic 7. Are you sure you picked the right pics? I know it's easy to get them mixed up when formatting a complicated tutorial, as I've gotten the wrong picture in the wrong place more than once.
Echoing Jack's inquiry, I'd also like to see more info on how you constructed your dovetail gauge.
annoying picture posting feature
Bill Tindall
When preparing a post with pictures it is important to not dawdle for if you do when the post is entered the pictures will have disappeared. It must be some time out property. Hence, for a long post the rush is on the get the pictures entered and the post submitted. Haste leads to errors. With pictures such an essential feature of WoodCentral it would be nice to have a more robust way of posting them. The other annoying feature is the need to delete arcane computer language from a copied link or the link doesn't link.
Re: annoying picture posting feature
William Duffield
Thanks. The timeout is what usually gets me, too.
