New WoodChat!
What size chop for twin screw vise?
Paul Erickson
I am trying to decide how large to make the twin screw chop on my new bench. I am figuring that 18" between screws should be sufficient for the majority of the work I will do, and due to the bench design have other options for those rare occasions when I need to clamp a larger piece. I could go with 24" but feel that the additional size would unnecessarily take up space and be a bit more awkward for general use.
Here is a mock-up. The green tape indicates where the chops will likely be cut. As shown, the chop will accommodate about 20" board, but I think it is a bit too large. The 2x6 in the middle will be an experimental movable jack.
This will be my first time with a twin screw vise of my own, so don't know what size I will need in actual practice. Any reflections will be greatly appreciated.
cheers, Paul
Re: What size chop for twin screw vise?
Wiley Horne--So. Calif.
Hi Paul and everybody,
I have installed 3 of the LV Twin Screws. But am not quite clear on your plan. Looks like it's on the bench front (not end). Coupla questions:
1. Where is the vise placed along the front? Does it reach to the end? Is there a reason you don't want it to reach to the end?
2. Will the rear jaw (chop) be flush with the apron of the bench? Or does the vise stand off from the bench?
Wiley
Paul Erickson
Hi Wiley,
Thanks for the response. As to your questions:
First of all, I am not using a veritas twin-screw, but two screws that I have already.
The vise will probably extend to the right end of the bench, but the main thing will be for it to be centered over the right front leg of the bench. There will be holes drilled in the leg so that I can use holdfasts to support the bottom of the board. The twin screw cop is shown in the picture to the right side of the bench.
The apron of the bench will be the rear jaw of the vise, so yes it will be flush with the apron and the leg of the bench.
Sorry I wasn't clearer in my initial explanation.
cheers, Paul
Thanks Paul,
The 18" should do fine. Maybe think about what is the longest length of dovetails you would ever want to saw.
The main thing I have found (this may be different for others, but something to think about) is that the most-used part of the twin screw vise is not between the screws. Instead, it's outside the screw, between the screw and the end of the bench. So I would suggest leaving yourself a few inches of clamping room there, outside the screw. Why? Because it's useful to be able to work at the corner. For sawing, it gives you flexibility with respect to standing in or arranging the best light. And for tenons, you can clamp the stick once, saw the cheeks from the end, say, then step around the corner and saw the end pieces from the front.
The corner is also helpful on drawer joinery. For example, if you go tails first, and are ready to transfer marks to the pins board, you can put the pins board vertically in the vise, right at the corner. Lay the tails over it, clamp the tails board down (you're at the corner, so it's easy to find a place), then knife in the transfer to the pins board. If the corner is square, which of course it will be, you can line up the drawer side along the edge, to make sure you end up with a square and plumb drawer.
Didn't mean to get this windy--am trying to say that the clamping space outside the screw, at the corner, can be very valuable. And the vise has great leverage at this point.
Wiley
Paul Erickson
Excellent, thanks very much. The discussion about the area beyond the vise to the corner is really helpful. Not long winded at all.
cheers, Paul
Very good info Thanks Wiley
