New WoodChat!
Kenyon iron?
Kenyon iron?
Kenyon iron?
I bought this iron recently with the intention of using it in a jointer plane. It is 2-1/2" wide and 7-1/2" long. The iron is laminated and 3/16" thick at the business end. It looks to be ideal for a single iron, wedged plane.
My eyes lit up at the name "J Kenyon", knowing this from Kenyon saws. The UK seller stated that the blade was New Old Stock and dated from prior to WWII. It has been coated in some goo and is certainly in amazing condition.
Here is the mark on the iron ...
I did a little research, and came up with ...
John Kenyon & Co. file manufacturer,
address - Hollis Croft, Sheffield.
Found in Pigot's directory, year 1828-1829.
John Kenyon & Co. steel & edge tool manufacturers,
address - Millsands, Sheff:
Kelly's directory, 1881.
John Kenyon & Co.
merchants & manufacturers of; steel, files, saws & edge tools.
address, Millsands Steel Works, Millsands, Sheff:
Trade Mark ..
Whites's directory, 1901.
& Kelly's directory, 1925
Here are images of the iron ....
It has a good lamination:
And the bevel has never been ground:
A close up of the lamination. It looks quite impressive to my eyes ..
So what can be said for the iron? How old? It is treasure or user? I want to put it to work, but feel the need to check it out with those more knowledgeable.
Re: Kenyon iron?
Do what you'd like to do with it..
david weaver
.... as you can get another one on ebay for about $30 shipped.
If you feel guilty about preparing and using a brand new iron, you could always buy a second!
there are "more than 10" available on ebay right now. The pictures shows them similar condition to yours.
Thanks to your topic, though, I ordered two of them. One with a slot and one with out.
Re: Kenyon iron?
Re: Do what you'd like to do with it..
Excellent!
I was not sure about the ethics of linking to the seller. I have two. There are more available for others, but the question remains with regard the real age of these irons. What do you think?
Re: Kenyon iron?
Re: Kenyon iron?
david weaver
I don't know for sure, but I would guess late 1800s to early 1900s based on the thickness, the stamp and the general look of the iron.
It's remarkable that a carbon steel iron survived without rust for that long, and in quantity at that.
It would be great if they were old enough to be pre-bessemer steel, but they probably aren't, and they might be a bit later than early 1900s, maybe even mid 1900s. Some of the marples planes had laminated irons up through the 50s or 60s.
Re: Kenyon iron?
Stephen Shepherd
Re: Kenyon iron?
Stephen Shepherd
Tools are meant to be used. Sharpen that old boy up and put it to use.
Stephen
Re: Kenyon iron?
James Watriss
I'm an ignoramus when it comes to collectability, Derek. But the phrase that comes to mind is 'ballpark, 100 years old... Back when people knew how to use these things, and knew how to make them, too.'
It is an exciting find, regardless of the specific date, but I do hope you get the information you're looking for.
I tuned up an old Spiers infill coffin smoother this week that has an old (I think) Mathieson iron in it, and (again, I think) Sorby cap iron. Neither iron nor cap iron was square, and the sole of the plane was far from flat, despite being steel. Some time with a belt grinder, followed by careful filing got the sole in good order. And the whole blade assembly is now square, with a 50 degree bevel on the front edge of the cap iron. And the screw is ground down so it doesn't bottom out in the slot. Clearly not OEM equipment.
...And a good scrub, and a wax job on everything...
The better part of a day later? Oh, jeez. That old steel is something else. The plane's a joy, and it's fancy and all, but it's all for the sake of holding the iron, really, and that old steel is magnificent. Enjoy yours.
Re: Kenyon iron?
The nature of the beast
Bob Hackett
I have a furry companion that is part wolf and her line was bred to pull sleds. She`s a beautiful beast and born to run, that`s her nature. We love having her around as she`s a kind and gentle companion as well as an excellent watch dog.
The one potential flaw in our relationship is that she also loves to do what she was brought into this world for and that is run. From time to time, when we least expect it, she will bolt and run for all she`s worth up the right-of-way and out of sight despite the number of times we call to her or the urgency in our voices. Some times one of us has to go looking for her because she gets carried away but most times she comes tearing back in our direction and runs laps till she`s run herself out. You can feel both the joy and the frustration in her. She wants to obedient and please us but she also has a need that she just has to indulge.
We have come to the point where we have embraced her nature and come to terms with her celebrating it. This has relieved a lot of stress for us and her both. It has also allowed us more trust and freedom to enjoy our partnership.
Hard to tell if there is a real problem in our relationship and which side the potential problem may be on if a problem really exists. Were we wrong for trying to re-program her and make a house dog out of an animal with instincts like she has had bred into her or is she wrong for indulging her true nature and not being as obedient as we`d like? Why should the idea of "wrong" even have enter into our equation?
I think, like most things, there is the potential for great beauty and joy in engaging in compromises which allows things to both unfold according to their true nature yet also leaves room for discipline and preservation. Releasing other`s ideas of what is right and what is wrong and being open to finding compromises that are flexible and do not fully embrace either end of the spectrum has brought a lot more enjoyment into my life as well as allowing me to share that joy with others more often.
Just some musings on indulgence vs preservation as it relates to my life.
Re: Kenyon iron?
Re: The nature of the beast
I'm not a good collector. With a single exception that indeed lives on a shelf, all the tools I have purchased are to use.
These irons are no different. They will end up in planes. However, because I may well modify them (I plan to reduce the width of one), and because of the name and new condition, I asked the question to check that I was not tampering with something of historical significance. There are a few more to be picked up if you search eBay. They deserve to go to good homes. I cannot imagine better homes than the members here.
Re: Kenyon iron?
James Watriss
I'm not much of a collector either. Still, it felt somehow sacrilegious to grind the sole of that old Spiers.
That said, now that the bottom is actually flat, it's probably the best fine smoother I own. Setting up is a breeze, no hammer needed. Turning the knob on the lever cap creates just the slightest amount of deflection in the body, and that's how I set depth of cut. It's ridiculously simple and precise way to set up for some very subtle shavings.
