New WoodChat!
Air drying pine
Air drying pine
Air drying pine
Patrick Gibbons
I've found a place where I can buy SYP in boards and timbers of practically any size. They are all green, so green that the timbers are cut while you wait. It's far enough away that getting it back home would be a chore. I've done some studying on air drying southern yellow pine and it can warp, check and stain easily if done wrong. No source I've read has recommended painting the ends. The prices are very cheap but I'm put off by the what ifs and dedicating precious space in my garage for a stack. Does anybody have experience air drying SYP they can share? I've also read that SYP can warp once again when it's cut into and I wonder if it would start to move after planing even though it was already air dried?
Re: Air drying pine
Things you need to know
Bill Tindall
What do you intend to do with the lumber?
It will stain quickly when dead packed if it is warm to hot outside. Need to get it on DRY! sticks and air moving through it promptly. Keep rain from infiltrating the pile. Covered and out doors in a place with good air circulation is best. With good air circulation 4/4 lumber will be largely dry in a month in warm weather. However, unless it gets hot the sap will not be "set" so you may be dealing with runny sap.
Painting ends is a waste of time for anything but very thick lumber.
Pine is very easy to dry. Stack it straight and level. Put some weight on the top of the pile- cement blocks or just 2 layers of some junk grade lumber.
If you can pick logs, pick logs (or lumber) with closer growth rings.
Lots of furniture got built using SYP and lots of Period reproductions are still being built with SYP. There is no special problem with this lumber.
Re: Air drying pine
PS
Bill Tindall
place sticks for drying every 2'. Spare no effort getting the base for the pile straight and level with good air circulation under the pile. I use a 4" cap block on the ground, then an 8" block then a 4 x4 then a DRY stick and then the first layer of lumber. I cover the piles with roofing tin with ample overhang, soped to shed rain. Rain blowing on side of pile is not a problem.
Re: Air drying pine
Re: Air drying pine
Ron in Sterling, CT
Bill has already stated it, but it cannot be overemphasized, to use DRY sticks to sticker the wood. Take it from someone who has been there and not done that.
Ron
Re: Air drying pine
Dale Lenz
Re: Air drying SYP
Dale Lenz
I've dried several M feet of SYP for framing material for my shop back in 1996, blue stain is a concern, but for framing material, not a concern. However, setting the sap is a concern, in furniture. Don't know how many years after completion of the shop some of my "sunny-boards" dripped sap on the hottest of days.
My advice is not to AD the SYP in your garage, put outside well covered and let the wind blow through the neatly stacked pile of lumber to get the wood's shell dry to reduce blue staining, may get a little bit of blueing, and maybe use that coloring in your design. As far as setting the sap: When lumber MC is below 20%, might put a few boards up in the attic during the summer to 'melt off' the sap as much as possible. My understaning is several day/weeks in the attic of say 140* should not allow the sap to run in less than 140* temps, so an interior of a house should never get that warm. The lumber ndustry heats the lumber up to something like 160* to set the sap, and maybe that's to reduce the sap from running in attic boards (??) Proceed with caution.
Re: Air drying pine
yes to attic sap setting
Bill Tindall
I have set the sap in SYP in the loft of our lumber storage shed which gets up to about 140 F in a hot summer day.
Re: Air drying pine
Re: yes to attic sap setting
Jerome Bias
Thanks for the tip on ways to control the runny sap. The SYP that i have dried in t he yard didn't quite set. I guess that is why many of the old timers in this area stack their SYP in the hay loft or attic.
By the way the powder post beetles love the stuff. Remove as much of the bark from the wood as soon as the logs are cut down. I have been surprised, by how fast the little boogers will bore into the tree. many of the old timers around here also spray or paint on a coating of a Boric Acid (concentrated solution of 20 Mule Borax). I have used both that or a product called Timbor with good success. I have also cried after losing some 23" wide boards of old growth SYP to beetles.
Good Luck.
Re: Air drying pine
bugs-Insecticide works too
Bill Tindall
A dousing with a persistent insecticide works too. I have used Lindane for years with perfect success.
Re: Air drying pine
Re: Air drying SYP
Patrick Gibbons
My parents bought a house in the late 40's which the family owned until the late 90's. The wood siding continued to exude sap the whole time we owned it.
