New WoodChat!
An Overlooked Hand Tool - Heads Up
charlie belden
Bevel up, bevel down, bevel angle, bed angle, oil stones vs water stones vs diamond plate, saw teeth types, saw teeth set, Clifton vs Stanley vs Veritas, Marples vs Two Cherries, push cut vs pull cut - handtools and their details. But one essential hand tool that I haven't seen mentioned is an Arm & Hand Extender.
If you use hand tools, one or more will invariable fall off the bench, land on the concrete floor - on its cutting edge or corner of its cutting edge - then bounce or roll under the heaviest object in the shop - far enough back that you can't reach it - and come to rest next to something that stings, stinks, bites or all three - and has an attitude.
THAT's where THIS essential Hand Tool pays off.
36" long, shaft clicks into either Jaws Parallel To Handle or Jaws 90s To Handle, with soft gripping jaws. Retrieve you tool and, if you're dextrous enough and quck enough, you can smoosh that stinking, stinging, biting little SOB ; )
My local ACE Hardware store has this essential shop tool on sale for $5.67. Bright yellow, it'll be hard to hide amongst all the stuff in your shop.
Re: An Overlooked Hand Tool - Heads Up
You didn't mention "vertically challenged"
Bill Tindall
The women of the family are all "Vertically Challenged", AKA short. They all own this handy tool. It makes top shelves useful.
Re: You didn't mention "vertically challenged"
Patrick Gibbons
My 11 year old has had one since he was seven. I find myself always borrowing it.
