New WoodChat!
Lee Valley's got an outfill plane! *LINK*
See the link. Interesting...
OK, maybe not an outfill, but...
Re: Lee Valley's got an outfill plane! *LINK*
William Duffield
If you are interested in the chamfering possibilities of this plane, there is another alternative, which may be able to get you chamfering quicker, and for less. Lee-Valley sells a chamfering attachment for two of their adjustable mouth block planes.
http://www.leevalley.com/us/wood/page.aspx?p=46296&cat=1,41182
Of course, to make it less expensive than the new "outfill plane," you have to already have their block plane. It is adjustable for width, but not for angle, unlike the glue-on fences recommended for this new plane. I have one that I use regularly, and it works well. It is easy to install and remove without any tools: you just remove the adjustable mouth block using the brass knob, and attach the chamfering attachment where the mouth block usually goes. You do have to remove the guide from the plane to adjust the chamfer width, using a flat blade screwdriver.
Unlike a hand-shaped wooden plane body that you designed yourself, it has a very utilitarian look and feel.
Transitional, revisited?
James Watriss
Reminds me of an old Gage transitional.
