Tapered blades rule ...
... in wedged woodies.
In the thread below on diamond plates - particularly the coarse end of the spectrum - what lay at the back of my mind was the recent experience of flattening the back of a tapered blade for a jointer I was building. The iron was a Sorby, 2 1/4" wide and 3/16" thick at the business end. This is pretty much typical of he tapered blades I use in woodies. Some are even thicker. The 3" wide Berg iron I used in a coopers jointer is around 5/16" as I recall. And both these irons are laminated with extremely hard steel. They took forever to flatten on 45 micron diamond paste.
These irons are thick enough to be used sans chipbreaker. Yes, a chipbreaker could aid the ultimate performance, but this is unnecessary in these planes. I still prefer the lack of complication from a single iron plane. The advantage from a tapered iron is that, when used with a wedge, it does not slip. I do not get this level of stability from a parallel blade when using a wedge.
I hope this discussion does not lead to a rush on tapered iron on eBay! Perhaps we need to get Lee Valley to begin production of tapered irons in PM-V11!
