New WoodChat!
Tuesday Night Hand Tool Chat - Treen *LINK*
Stephen Shepherd
Stephen Shepherd
It is Tuesday once again, the night we get together and discuss HAND TOOLS and related Hand Tool Subjects. Tonight's subject will be treen and treenware, thank you David. You can see the post on the HAND TOOL FORUM concerning treen and it's general definition.
The fun and frolic all starts at 9:30 o'clock PM Eastern Time and runs for one scheduled hour. Just click on CHAT ROOM on the left and join in.
All are welcome, hope to see you there.
Stephen Shepherd
Host - Hand Tool Chat
Treen
Re: Tuesday Night Hand Tool Chat - Treen *LINK*
William Duffield
The Bench Dawg is out in the back yard treen' a squirrel, so I'll invite her to the chat. She's an expert.
It the linked thread, David asked for info on treen and also on work in mixed media. I posted some photos of mixed media, but didn't show stuff I've made for the kitchen that were mostly wood. As soon as I get back from the post office, I'll find and shrink some pics and post them here.
While you're waiting, Ceci n'est pas une pipe.
One of these is not a Milkbone; it's Liriodendron tulipifera.
Re: Treen Examples
William Duffield
Some treen I've built:
Salad tongs, spatula, cheese knives. (walnut, cherry, purpleheart, olive burl, cocobolo, padauk)
French rolling pin, soup spoon, dough paddle, rack to hold them. (Guatambu, black cherry)
Antique cast iron spice mill, new handles (teak). 7" Ø wheel. The pattern left an impression of a knot in the wheel. This is the only mill I have found that is competent at grinding whole allspice.
WebBBS is starting to eat pictures again, so I'll post these before I go find some more.
Re: More Treen
William Duffield
Four views of two ladles, one left handed, and a spatula. (mahogany and teak)
Another spatula (purpleheart and dogwood). I make these with one square corner, and just narrow enough to fit in a Contadina tomato paste can.
Weed pots, for dried flowers. This shows the back side with a flat and a rare earth magnet, for the refrigerator door.
Three more. These have flexible clear plastic tubing inserted, with hot melt glue sealing the bottom of the tubing, so they will hold fresh flowers. (Black cherry, pink dogwood and golden rain tree)
David Barnett
(Message Deleted by Poster)
David Barnett
Magritte. Milkbones. Popple. About right, I'd say.
Re: The most unkindest cut of all!
William Duffield
Polyurinate?!?
They are finished either in pure walnut oil (Loriva, from the grocery store) or in Loxahatchee Toolworks Frog Polish (Top Secret formula, SDS unavailable), depending on whether I expect them to be dropped into a kettle of bubbling tomato sauce.
These treen were made before I started using Mahoney's Utility Finish instead of Loriva.
A small vial of oil of Juglans regia, a grey ScotchBrite (or equivalent) pad and the following instruction sheet goes out with all my treen. (Note the reference to Pinto in the Wikipedia article. :) )
Care and Feeding of Loxahatchee Toolworks Treen, Including Cutting Boards, Spatulas, Spoons, Salad Forks, and Cheese Knives
These tools are made from stable, seasoned hardwoods of various durable species. West System epoxy adhesive is used to glue individual pieces of wood together. The finish is walnut oil.
Walnut oil is a semi-hardening food-safe finish. It can be put in contact with food immediately on applying. Most other wood finishing products, including "Salad Bowl Finish" require a complete cure before use. While butcher block oil and mineral oil are also immediately food safe, they are not hardening, and therefore are washed away with hot water and detergent, requiring more frequent application for protection of the tools. The walnut oil finish does benefit from a day or two of curing to improve its protective properties, and to minimize the frequency of reapplication. I use Mahoney's Utility Finish. Loriva brand walnut oil from the grocery store also works. Read the label! Other "Walnut" oils, that are adulterated with other vegetable oils, or "vitamins" are not suitable.
I recommend using the grey Norton pads for reapplying the walnut oil, as they are impregnated with a finer grit abrasive than the green ScotchBrite pads that are commonly found in grocery stores, and result in a smoother finish. These pads also remove the "raised grain" fuzz that results from the wood getting wet in use.
When renewing the finish, for best results, thoroughly wash and dry the tool. Apply walnut oil to the grey polishing pad, and rub it vigorously into the wood, in the direction of the grain. It is especially important to apply sufficient oil to the end grain. Wipe off excess with a paper towel, set on edge, and let dry for 24 to 48 hours. To keep oil from drying in the polishing pad, wash out the pad with hot water and detergent.
Do not wash these items in the dishwasher. (The only dishwasher safe treen I have found are spatulas and spoons carved of a single block of teak or purpleheart.) Scrub off food residues and dry after use. Do not leave them soaking in the sink. Do not leave cutting boards lying in a puddle of water on the counter top. Store on edge. If stored flat, the upper surface will dry and shrink more quickly than the lower surface, and the cutting board will cup. Do not stand cutting boards on end to dry. To prevent end checks, stand cutting boards on the long edge or preferably in wire dish drainer.
Article from Wikipedia:
Treen is a generic name for small handmade functional household objects made of wood. Hence treen is distinct from furniture, such as chairs, and cabinetry, as well as clocks and cupboards. Anything from wooden plates and bowls, snuff boxes and needle cases, spoons and staybusks to shoehorns and chopping boards can be classed as treen. Domestic and agricultural wooden tools are also usually classed with treen.
Before the advent of cheap metal wares in industrialized societies, and later plastic, wood played a much greater part as the raw material for common objects. Turning and carving were the key manufacturing techniques. The selection of wood species was important, and close-grained native hardwoods such as box, beech and sycamore were particularly favoured, with occasional use of exotics, such as lignum vitae for mallet heads.
Wooden objects have survived relatively less well than those of metal or stone, and their study by archaeologists and historians has been somewhat neglected until recently. Their strongly functional and undecorated forms have however been highly regarded by designers and collectors.
The scholarly study of treen was greatly advanced by Edward Pinto (1901–1972), who started collecting in his childhood and wrote a definitive book on the subject. In 1965, when Birmingham Museum & Art Gallery purchased his collection, it contained over 7,000 items.
David Barnett
Re: You DO know I was pullin' your chain...
William Duffield
No, I figured you were pulling my frog leg :D
I also use a lot of the white Norton pads (I buy them by the case too, in three colors), especially when applying the Frog Polish on the lathe. After initial application of the Walnut oil with the grey pad, I put walnut oil on one white pad and shellac (usually SealCoat) on another, and apply them alternately, while the lathe is spinning, rapidly.
And now y'all know the Loxahatchee Toolworks secret finish. No SDS, because everything is food safe, as long as you don't try to drink the bug spit before it has cured.
The lantern sits right next to the frog pond, which was always an inspiration to Loxahatchee.
Eh?
"I also use a lot of the white Norton pads (I buy them by the case too, in three colors)..."
That would be bone, cream, and titanium white?
Re: Eh?
William Duffield
We're talking about the abrasive pads, similar to ScotchBrite. As far as I know, the finest pads (polishing, no abrasive particles) are just white. The pads with different grit abrasives are produced in dark grey, maroon and green, but not bone or cream.
