Pictorial for critique
Patrick and all
As it happens, today I needed to create a shallow mortice, and the techniques involving the router plane, and where it fits in, were involved. It only dawned on me to take pictures after I had begun, and so the process starts with the marking, hatching and rough waste removal already done.
The task involved was to create a mortice for a brass mouth piece for a jointer plane. This is identical to setting a hinge mortice. (Incidentally, this is the last laminated plane I will make. With the memory of the plough plane in mind, it is more work that chopping out the bed and mouth. I had the parts, so just used them).
What you note here is that I am working within the defined boundary.
In paring out the waste, try to work across the grain to avoid tearout.
The same technique applies when using the router plane. The router's depth is set, and then reached incrementally.
By the way, I hollow grind the faces of these router blades. They are then easy to hone to razor sharp ..
I decided the V blade would work more easily into the edges. This was already set up in my shop made router, which was also smaller and easier to maneuver. Again the bevel edge is used across the grain ..
The edges of the mortice were finished by scoring with a cutting gauge ..
Left with just the front section to remove, treat it like a dovetail and undercut the line. This will ensure that the chisel does not move over the line ..
And finally the fitting tells all ..
