New WoodChat!
Query for Ellis
Query for Ellis
Query for Ellis
Ron in Kokomo
I can't upload photos. I gave a profile. I am using an IPad?
Ron
Re: Query for Ellis
Re: Query for Ellis
Bruce, a MN Galoot
The problem is with the iPad. I can't upload photos directly from mine, either. You can upload if you store the photo on a mass storage site like flickr or photobucket and then link it from there. If someone knows how to directly upload photos from an iPad, I'd sure appreciate it. It's a pita to have to walk all the way across the house just to use the computer :D
Re: Query for Ellis
One part of an answer
Ron,
Ellis will need to weigh in on the iPad question - I don't know that answer.
But you're not using your profile name, so you wouldn't be able to upload even if you were at a computer. I've sent you an e-mail.
Re: Query for Ellis
Looking into it
Hi Ron,
Bill is right, your registered username is "roninkokomo" (no spaces or caps), not "Ron In Kokomo," which means you wouldn't be able to upload photos from your computer anyhow. But, specifically in regard to the iPad, I just tried it with my wife's iPad and find that the "Choose File" button is grayed out, which probably has something to do with the code that generates our forum. I have sent a note to our developer in Hamburg, Germany, to ask if there is a workaround. I'll let you know as soon as I find something out.
Thanks for the heads-up.
Re: Query for Ellis
Thank You
Re: Query for Ellis
Short answer: No.
According to our developer, this is an Apple issue. They are well known for not allowing Flash files or printer connections on their portable devices. This apparently extends to their decision not to allow uploading from the iPad.
I'm just the messenger here and not at all conversant with the technical background of all this, so if I'm wrong, don't shoot me.
Meanwhile, if you can store your photos somewhere online or in the cloud, you should be able to call them in the "Optional Image URL" textbox. That's the best I can do. Sorry.
Re: Query for Ellis
Re: Query for Ellis
William Duffield
I haven't figured out any way to do it from my new iPad, either. If anyone finds an app that will let us do it, please let us all know. At SAPFM mid-year, there were four iPads at the table I sat at. No one else knew how to do it either. This was frustrating, as we couldn't post any photos until we got home, or we had to find someone with a macBook.
My strategy, FWIW, is to take photos on my Cannon Elph, and then download them to th iPad to look at immediately, and then download them again from the camera to my computer at home, for archiving, editing and posting to the web. The camera takes better photos than the iPod, takes up a lot less room, has a zoom lens, tripod mount and flash, and the battery doesn't need charging nearly as often.
Re: Query for Ellis
What is possible from an iPad ...
I am fairly new to iPads - I purchased the #3 about a month ago as a substitute for my MacBook Pro for a conference overseas (the laptop was too heavy for extended lugging around). I quickly added a wireless keyboard as this made life much easier with serious typing and cut-and-pasting.
Yes, Apple limit what can be done. As noted earlier, it is preferable to link from an external source, such as Photobucket.
There is an issue with Photobucket as well, unfortunately. When I access PB, the Index page is rigid/unmovable. If, like myself - trying to be organised - you have that many Albums that they run off the screen, you will not be able to access the ones off the screen by scrolling down. The work-around is to go to "All Albums", but this is tedious (to say the least) as you then are taken the long way around.
If you wish to copy-and-paste from a web image, do a two-finger wave and choose "open image". Then copy the address and paste it with the pre- and postfixes: [ img ] ... [ /img ]. (Edit: there should not be any spaces in the DOS instruction. I left these in as otherwise you will see an error message).
Now if you use the iPad to take photos, and wish to get these onto Photobucket, you have one option in my experience so far (and another that may bypass this). You cannot upload these images directly. Apple will not let you, but ....
There are two methods (so far):
1. The first is to use email to send the image(s) to your home computer for uploading.
Open photo and click the top right hand corner of the screen for email.
2. I have an App. on my iPad called "File Manager". This is not as extensive as Windows Explorer or Mac Finder or MacIntosh Explorer, but it does show all images on the iPad, and it will also permit emailing.
Most importantly, File Manager has a Dropbox facility ... and so does Photobucket! I have only just discovered this so cannot say if or how well it works, or how to do it. But this may be the way to go. Experiment and share your experience here.
Re: Query for Ellis
Solution!
Use Dropbox.
Replace Photobucket et al with Dropbox, that is, store your pictures in albums on Dropbox, and download from there.
Note that you need turn on the facility in Dropbox (App) on your iPad so that you can upload images from the iPad to Dropbox on the web.
Example (desk by David Haig) ...
Regards from Perth (and iPad)
Re: Query for Ellis
Re: Solution!
William Duffield
Nope, it's not a solution. Viewing your image is password protected. All we see is a blue question mark.
But, thanks for trying.
Re: Query for Ellis
Re: Solution!
OK, all we have to do now is remove the need for a password. That shouldn't be difficult. Just need to look it up. Anyone want to say how and save time?
Re: Query for Ellis
Re: Short answer: No. *LINK*
William Duffield
Printing isn't totally disallowed from an iPad. Some apps support printing to an AirPrint enabled printer. My printer, even though it has WiFi, happens to be one version too old to support AirPrint >(
iOS: AirPrint 101
Re: Query for Ellis
David Barnett
You did it, Derek. Nice little desk.
Re: Query for Ellis
Re: You did it, Derek. Nice little desk.
Hi David
thanks for the feedback. That is a relief. For all interested parties as well.
Yes, the desk is a beauty. It was designed and built by David Haig in New Zealand. I am about to start a version of this.
I finally found an app that gets images from the iPad to the website (forum): Picup
The link is here:
http://itunes.apple.com/us/app/picup/id354101378?mt=8
Re: Query for Ellis
Stuart Johnson
It appears this is a link not an upload where the picture is an embedded file. While this is a good way to get the pictures posted won't they be lost if there is any type of source link or service change? If that is the case then I think over time the WC archives will become less and less useful.
Re: Query for Ellis
Pictures on a forum
Hi Stuart
Only Ellis will know the actual statistics of uploaded versus linked images. I am unsure what the percentage use of linked images has been over the years. All the images on all my posts are linked from Photobucket. Until recently, this was the only way to post multiple pictures.
The iPad-based images are also links. It is the only method open owing to the limitations Apple imposes. For reference, while Photobucket offers a link for iPads, this is only to download and not to upload images. You also cannot use Picup to upload to Photobucket. Picup uses its own database.
The purpose of an Archive is to save articles along with their pictures. The way this is done is to make a physical copy of the article, and then save this (and not the link). The dependency on a linked picture then is removed. So I guess it is up to us to decide what is worth saving and to Ellis to determine the cost of doing so, and to join forces in making this happen.
Re: Query for Ellis
Re: Pictures on a forum
"The purpose of an Archive is to save articles along with their pictures. The way this is done is to make a physical copy of the article, and then save this (and not the link). The dependency on a linked picture then is removed."
Ellis can speak to this in more detail, but copyright issues would pose a problem with this approach. Linking to an off-forum web-based publicly available image of whatever form does not, as I understand current US law, create a copyright problem because the person/organization posting that image has chosen to make the web address public, and pointing to that web address respects the ownership of the image. Appropriating the image for our own use - making it internal to WC - would probably violate copyright, and certainly violates the principles of intellectual property.
Not that it couldn't be done, but Ellis is a busy lad, and the vast Wood Central support staff...doesn't exist.
Re: Query for Ellis
Re: You did it, Derek. Nice little desk. *LINK*
William Duffield
The "Imager" photo database to which Picup uploads photos does appear to be free. They reduce the size of images you upload to them to 1 Mbyte. The maximum image size you can upload is 10Mbytes, but you would be smart and efficient to reduce them in size before you send them. And they may remove images that have not been viewed once in 6 months. See FAQs at link.
So, I guess the rhetorical question might be, "If no one is using the information, why should we be concerned with archiving it?" On the other hand, if the photo is part of a write-up that has general long-term value, then we should convert it into an article and let Ellis archive it in the standard manner on WoodCentral. As Bill notes, there are copyright issues. If the photo was created and uploaded by the author of the article, then could it be used if we included some statement by the author and photographer that the photo is theirs and they give permission to WoodCentral to reproduce it? Alternately, during the editing of the article, could the author resupply the original photo, via e-mail to our editorial staff?
Yes, I know we don't currently have an editorial staff, but if we keep discussing the problem and the advantages of articles, we might actually turn over a rock and find an article editor hiding under it. :)
http://imgur.com/faq
Re: Query for Ellis
There is a copyright issue with using photos that don’t belong to the poster/author of the thread or article, and if we need to use other people’s images, we need to get permission. However, 99% of the pictures that people upload to their posts are ones that they have taken themselves. By uploading them to WoodCentral, they imply that they own the images and are transferring non-exclusive rights to WoodCentral to publish the images. If we find images in threads that we know are not owned by the poster, we remove them forthwith. Links to images are fine.
By the way, that "non-exclusive" part is important. The owner of the images doesn't assign copyright to WoodCentral by posting them, but he/she allows us to continue to use them.
Re: Query for Ellis
That will definitely mess up the archives. Also, if you embed an image link that calls up a 1Mb photo, a lot of people are going to be unhappy with the download times.
If nobody cared, we shouldn’t. But, we know from past history that a lot of people do enjoy archived materials, and our forum archive system isn’t particularly user-friendly, so creating articles for posterity is a great service, and frankly the greatest potential legacy of this site.
That isn’t necessary, as uploading the photo to a site automatically grants permission. No attribution is necessary, although we could certainly give photo credits if anyone wanted them.
That wouldn’t be necessary unless the original photo that was posted in the live forum was substandard or too small. We would just reuse the original.
Hmm, I wonder if there are any rocks in the Cohansey? :) I know that Michael Donaldson has offered to help with an articles initiative, and if we talk it up some more, maybe we can pull something together.
One thing I would also like to do is deputize everyone who visits this forum to tell us which threads they've enjoyed the most over the years, a "Best of WoodCentral" wiki type of thing. Those threads would be the prime candidates for archiving, whether or not they have photos in them.
And, speaking of editing, I should note that there are no absolute standards for editing this stuff; it's all relative to the publication. In our case, there are very real time and cost constraints, so editing must be done swiftly and without undue fretting over details. Length and clarity are always prime objectives for editors, so anyone proposing to edit these things has to have a knack for deleting everything that isn't essential to the article or story. Of course, we don't want to remove the flavor from the stew.
This is a good discussion. I'll do everything I can to rejuvenate our articles program, but I can't do it alone.
