Progress on chest of drawers
Bill Tindall
These two pictures show the stuff involved in making the half dovetailed drawer dividers. A couple of points to make.
1. The desired precision for this joint is boggling. For stress-free assembly it should dry fit with modest hand pressure. I chisel it purposely tight. Any tiny over sized error and it becomes perfect. If it turns out a bit tight a shaving off the divider with a hand plane and it will be perfect. Editorial: I can't imagine why anyone would use a double tail in this application.
2. If the straight part of the tail socket is sawed perfectly perpendicular to the case side the divider will slip in and be perfectly perpendicular to the case side, a most desirable situation during assembly. Fitting drawers into a perfectly square case is easier.
3. A case made this way becomes a fortress of rigidity.
