New WoodChat!
Cool old miter trimmer
John in NM
I know this kind of trimmer isn't for everyone, but this one is awfully neat, and the price was right (free :D)
Brand is Perkins & Co, patented April 7, 1891
In addition to being heavy, really heavy, the blades move in an arc giving a slight shearing action to the cut. The handle also has what looks like a small section of rack gear on it, but doesn't engage anything. I wonder if they used the same handle for another design that had some kind of gear mechanism.
Re: Cool old miter trimmer
Jim DeLaney, Austintown, Ohio
That's really neat! It actually looks better made - and more practical - than my old Lion trimmer. I've never seen one with an arced blade path. It ought to make the shearing action even easier and cleaner than the Lion.
The castings on that one look a lot heavier than the Lion, too.
"I know this kind of trimmer isn't for everyone.."
...but probably 99% of the folks on this forum are now turning a light pea-green with envy. Good score!
scott grandstaff
Re: "I know this kind of trimmer isn't for everyon
scott grandstaff
This is the best I ever saw!
It adjusts a full 45 left AND right, on each fence.
Being an old Lion user for decades, having the capability to cut the opposite way is priceless!
Make a cover for it! Safety safety.....
(I used heavy leather for mine but wood is fine too.)
Then clean and tune it,
and send it along to me!!!
yours Scott
Kevin French
They are GREAT for cleaning up miters. A nice old Langdon mitre box, 26" Disston saw and that trimmer. Bring on the finish work.
Don`t think it`s a gear
Bob Hackett
I believe what looks like a gear is actually a slotted quadrant. Engaging different slots allows different handle positions.
scott grandstaff
scott grandstaff
Sometimes
I am almost done with 500 ft of old growth doug fir molding I made for friends. (the stuff is just plain house jewelry!).
The genuine old growth vertical grain clear was something I thought I'd never see again. But an old tyme hardware man (screw borgs) went back through his old connections, and got it!
Anyway, the trim could have gone easy. Except every door facing was cut oversized or undersized, and I did more work on the backside of each piece than I did on the front!
In case you thought I had a 7hp shaper with a giant cove bit? Uh, not in this town!!
yours again Scott
Aha!  I bet you're right...
John in NM
I'm heading down to the shop now, I'll take a closer look at that side of it.
maybe...
John in NM
Here are a couple more pics, the gear looking part is above the pin that engages the mechanism, but the handle is secured with a bolt right where the gear thing is. I would expect more holes, one for each position, so I wonder if there were another part that broke or didn't work right that engaged the slotted part, and the bolt is retrofitted.
As to weight, it is much bigger and heavier than the other one I got in the same deal, one of those Taiwanese copies that Woodcraft carries - got them both from a friend who didn't use them enough to keep tripping over them.
Re: Don`t think it`s a gear
William Duffield
That's exactly what I would have guessed, but I can't see the rest of the mechanism, and have never seen one like that in person, so I figured I'd wait and see if someone else knew the answer. It makes sense, as you would want to apply your highest pressure at different points in the arc, depending on different thickness of material and maybe even different height of operator.
Re: maybe...
That bolt has a distinct "field repair" look to it.
If the quadrant was originally for handle angle adjustment, I'd expect to see evidence that the handle once had a fitting in that area - holes, a broken surface on the casting, etc.
scott grandstaff
Re: maybe...
scott grandstaff
Its a gear.
I suspect its possible this model was available new with either a hand lever or a full base and foot treadle, as all the large trimmers used.
The original owner maybe wanted a "slightly" more portable unit and ordered the hand lever option.
Its also possible the base and foot treadle linkage was damaged along the line somehow, and the simple lever was substituted.
yours Scott
Gears Needed?
I have a Lion but have never seen the trimmer you have. But I wonder why gears or leverage enhancement would even be needed? Similar to the Lion, this would be a miter "shaver". With a sharp cutter you don't need a lot of leverage to shave the miter.
T.
Jim in Burlington Ont.
"Shaver"
Jim in River Oaks, Ont.
Hey,
Who you calling "Shaver" willis??
I shoot my mitre's with a plane... less storage space issues...cool tool none the less.
Take care,
Jim
