New WoodChat!
Bent irons; new tool tip?
Bruce McCrory
This morning I took a break from whaling on band-sawn cedar with my Bailey #6. And, took it in to sharpen the iron for the first time. I got it some time ago from a non-eBay list (a collector). I'm honing and touching up, ... then mounting chip-breaker, and notice daylight between chipper and iron. Lots of daylight.
Ok, this was done intentionally.
There is an embossed area on the back of the chip-breaker curve from clamp(?) or some bearing tool to bend the chipper face. The edges of the chipper dihedral like wings, away from the iron.
And, the iron has been bent. Not once, but I see 3 distinct chords of curvature between edge and chipper screw. The iron bends into the frog, concave to the bevel. The back appears to be flat laterally, as flat as the grinding wheel finish of some past cleaning operation allows.
Does anyone have any thoughts, of why this was done?
BTW, it cuts better since sharpening. Knots being sliced explode, like breaking light bulbs. My grunts were louder before sharpening.
Re: Bent irons; new tool tip?
Jack Guzman from Maine
I'm not sure I understand your description .However,the iron should have no bends. The meeting point between the chipbreaker and iron should be tight,no light at all should get through,. The breaker meeting edge is trued with a file or stone to make a tight fit with the iron. The breaker has a curve just before the meeting point(if it is a factory original breaker). Aftermarket breakers are sometimes different in shape.---Jack
Bruce McCrory
The modifications were so determined I thought someone had a tool working secret. I didn't want to get my club out and undo a fantastical tuneup I didn
't know about.
I should have given the bumpy grinder cleaning more credit. Guess what I am doing tomorrow?
