New WoodChat!
A55 Smoothing Plane
router plane question
Bill Tindall
For some years I have used a rehabilitated Stanley router plane that came with a single straight bit. It became a tool that I found a multitude of uses for in spite of the fact I once wondered what they were good for. In an uncharacteristic indulgence I bought a LV router plane convinced I would be happier with a more secure adjustment mechanism (I am).
It came with a diamond pointed bit. What is this profile used for where it is advantageous over a straight bit?
Re: router plane question
Stephen Shepherd
Also...
Stephen Shepherd
it works great on dado and dovetail dado work. The diamond or V point has relief that allows it to get into the undercuts easily.
Stephen
Re:The things you tink you know...
TomD
I always thought it was for roughing, and that is how I use it. I find the thin edge of the wedge effect is more efficient for levering up material. I also use it in both the drag and corner senses specified. It is the blade I most commonly have mounted. I guess I can now also use it for finishing.
