Stone advice
Bruce, a MN Galoot
Not "stoned", either!
I have two 6000 stones, a King 6000 S-2 and a Suehiro 6000-3. Is either worth keeping? Or, if I should keep one, which one?
Thanks.
Stone advice
Bruce, a MN Galoot
Thanks.
Re: Stone advice
Schtoo
They're both small, so have very little value on the used market, unless they're new. Not a little bit used/tried, new.
I prefer the Suehiro. A little softer than the King, but at the #6000 level a little soft isn't bad and while I've not used either stone extensively, I've always been happier, faster with the Suehiro.
If they're both new, see what you can get for them. Neither stone is particularly 'bad' though and I'd just use them up.
Hope that helps.
Stu.
Thanks, Stu
Bruce, a MN Galoot
I acquired these long before I started reading your advice or learned of the availability of the much better stones on your site. Too bad for me.
Re: Thanks, Stu
Arch_E
Stu has influenced quite a number of us--quite happily so!
I can't begin to list the number of people on WC
Bruce, a MN Galoot
who have had a strong influence on my woodworking.
I just went out and did a spark test on what I thought was cast steel and learned that my 1" X 3" X 12" slab of metal is, in fact, cast iron. Using what I learned from Bill T and a host of others on this forum I got my A2 block plane blade sharper than it ever has been before. I started with 3 micron diamond on the CI, followed by a trip down the 6000 Suehiro, followed by Flexcut gold compound on leather. Uffda! the things I've learned here.
Now, knowing that this big chunk of FE is cast iron, I'm going to have it surface ground so I KNOW it's flat.
What a pleasant surprise that must have been
If, by "pleasant surprise"
Bruce, a MN Galoot
you mean that it was cast iron, then yes, that was pleasant. I had been told that it was cast steel.
I wasn't a bit surprised by the results. It also means I can get some .5 micron paste and use that on the back side of the iron and go straight from diamond to the strop.
