Sticking Board questions
William Duffield
In the past, I've hand planed quite a bit of molding, but it's usually been either replacement gingerbread in the late 30-30* style and buried in paint, or really simple (or done on a router table).
Recently, I've been watching Don McConnell's DVDs from Lie-Nielsen, reading Matt Bickford's blog, "Musings from Big Pink" and excerpts from his soon to be released book. I need better techniques, and also better tools, including a sticking board, something better than just clamping a board to my bench top to use as a fence, and another one to use as a stop.
A question to those who have a sticking board and have used it to stick moldings: What details of the design and dimensions work for you? Don McConnell uses one with a wide but not very high fence, that can be adjusted horizontally. Matt Bickford, OTOH, uses one that looks and acts like a long bench hook, with a high fence on one surface, and a lower fence on the flip side.
Of course, everyone's sticking board uses a variety of adjustable FHWSs as end stops, sometimes some at both ends, and they hold the sticking board between a dog in their end vise and a dog placed near the other end of the bench. For now, I will probably use a Veritas wonder dog at one end. I will also need to be able to plane on the board in either direction, as I'm left handed, and have a left handed rabbet plane, but my hollows and rounds are right handed.
So, is adjustable width more important, or is a board that is wide, and the fence therefore farther from the front edge of the bench (where it will give my back more grief), but with adjustable height, better or worse? Are there alternate designs that work better, or that resolve this dilemma? How long does it need to be (I don't plan on wainscoting a whole house, but you never know)? My bench is about 7' long. What is the maximum working width that you have found useful?
As far as materials, I think my choice is tulip poplar, but if that isn't appropriate, I might be convinced to use guatambu plywood or even MDF. What works best for you?
* to be viewed from 30 feet at 30 mph.
