New WoodChat!
REAL MILK PAINT
Tapering a blind mortise
Jack Guzman from Maine
When boring mortises into the seat of a windsor chair I drill a through hole and then taper it using a tapered reamer. However,I noticed that many old windors were made with blind mortises. Were these tapered? If so how would I accomplish this? The reamers I have taper to a point and would not work because they would bottom out before they could start cutting.---Jack
Re: Tapering a blind mortise
Bruce, a MN Galoot
Did you make your own taper reamer, Jack? I'm watching the Buchanan videos and he has me very interested in attempting one. Time to start acquiring a set of tools, not to mention a maple tree.
Warren in Lancaster, PA
I have two different Windsors from around 1810. The leg tenons do not go through and they are not tapered (or wedged). On the same chairs the back post tenons are through the seat, tapered, and wedged. I think 18th century chairmakers would have had reamers similar to yours and would not have tapered a blind hole.
I bought my reamer from Elia Bizzarri. The one that Curtis Buchanan uses was also made by him. You could probably make one pretty easily from a compass saw blade.It's a very simple tool.---Jack
I think you're probably right. Thanks---Jack
Wedges??
Ron In Kokomo
Would they have wedged the tenons as they drove them home??
Ron
Philip Duffy
Bruce, I made mine and the only problem was finding a suitable saw blade. The recommended ones are not made any longer. I used a similar one bought at a Big Box. Phil
eliot d
How about a tapered flute pipe reamer?
That is something I'm going to try.Thanks---Jack
