New WoodChat!
200+ woodworking book reviews
Recent project
Recent project
Recent project
Bill Tindall
Daughter needed a corner cabinet to hide the air return for AC and provide some functional storage. Some neat custom metal shelf brackets attach to the wall above this unit. Son in law likes to do woodworking and learn. So we spent part of two days making this cabinet. He wanted to learn fine furniture techniques so this cabinet was made as though it was to be a traditional corner cabinet. The cabinet frame is mortised and tenon as is the door. He had almost no experience with hand tools and I was surprised how many hand tool operations were involved that could be learned from. He pared all the tenon shoulders, for example.
I must comment on the continued success of the tight cap iron arrangement. The cabinet frame was attached to the cabinet proper and then its edges planed to a perfect fit. I picked frame lumber to make the planing easy. An undetected pin knot popped up and torn grain in the knot vicinity resulted. (I was using a plane that was set up before the revelations of Kato and Kawai and Weaver). I moved the cap iron close, only by eye, and the next stroke of the plane went smoothly. While this cap iron thing may not be the solution to all planing problems it has solved the simple ones I have encountered.
Re: Recent project
PS
Bill Tindall
The floor was reclaimed flooring they found. The lengths were up to 12' with the most of it around 8'. When is the last time anyone has seen 12' strip flooring! It had been nailed with huge cut nails but because they are tapered they popped out readily. It finished up nicely.
Re: Recent project
The better man . . .
steve mackay
Get'n all those angles to meet up in the right shape is tough stuff. AND I'll bet that corner ain't a "real" 90 ! You're a better man than I am !
Re: Recent project
bridger
Re: Recent project
bridger
I hope you are allowing for airflow to the return register. if not you will unbalance the air handler.
Re: Recent project
Re: Recent project
Bill Tindall
The opening is in the adjacent room. The corner cabinet cover the duct. This house is short on closets so there was not a closet available to hide the duct in and it wound up in the living room. This cabinet, and the shelves above, will be an attractive disguise.
