Re: One might think that...
Wiley Horne--So. Calif.
Thank you David, Stephen, and Charlie, for the inlay methods!
The aesthetic point that Stephen makes (using one syllable* words) is best answered by seeing that nature is often a little imperfect when you look close--vines are twisted, not always smoothly; leaves will be bug chewed or sun scorched, or have tips bent at odd angles, or the 'wrong' number of lobes, and so on. Japanese artisans have long been onto this point, and Charles Greene used it in the Gamble House ornament. That said, my own effort may well turn out to look like--and be--a bad inlay job. Trying to avoid that.
I think the inlay on that desk is slightly raised. It looks to be a little proud of the ground, and raised inlay was used on other furniture in the Gamble House. Will verify this on the G&G forum to make sure.
I began with the notion to shape the wire, then cut the channel somehow in varying width to match. After reading and re-reading David's posts, it looks like it should be the other way round--the channel will be used to shape the metal, to avoid gaps where the metal doesn't fill the channel. Though it should be possible to press a shape into the wire against a wood or metal anvil just prior to sinking it. The craftsmen executing those G&G designs were often European ex-pats; but I've seen nothing describing their methods.
Am now thinking three stages:
1. Outline the channels shallowly with various gouges, and perhaps a graver (never used a graver). Gouges will be ground to thin bevels.
2. Deepen and shape channel with tools from scraper stock (per Charlie), hacksaw blades (per Stephen), and maybe a graver if David has a particular suggestion. It looks to me like a 'tooth' which tapers could be pulled along the channel to vary the channel width--more upright to thin the channel; held at a flatter angle to broaden the channel.
3. Undercut slightly with a thin, curved 'tooth'.
4. Choosing and working the wire will have to be an experiment--never done it before.
All further suggestions will be most appreciated!
Wiley
_____
*Winston Churchill, ".... “Short words are best, and old words, when short, are best of all.”
